4.1.03
7 years 2 months ago #18721
:Light 4.1.03 is online.
available for almost every supported 64bits systems. (Mac, Pc)
massive new features for those who uses incoming data to control channels/Sub...
Enjoy,
4.1.03 was created by sl1200mk2
:Light 4.1.03 is online.available for almost every supported 64bits systems. (Mac, Pc)
Enjoy,
- SoundSurfer
- Thank you received: 3
7 years 2 months ago - 7 years 2 months ago #18722
by SoundSurfer
Replied by SoundSurfer on topic 4.1.03
Hey,
I downloaded and installed the new version. But my mac says it unable to open DL::Light.app ...
running 10.11.6
I revert to DL_4.0.32_b1_XQuartz_MacOS_10.9_Minimum that works fine.
Any clues?
attached picture show the message. (my OS is in Dutch)
kind regards,
Jannes
running 10.11.6
Any clues?
kind regards,
Jannes
Last edit: 7 years 2 months ago by SoundSurfer.
7 years 2 months ago #18726
Replied by sl1200mk2 on topic 4.1.03
Hi,
Sorry about that... Apple new policy regarding application distribution is a pain and it seems code I wrote is not yet bullet proof...
For now I don't have any solutions until early days of September.
Did you tried to Ctrl+click on DL icon and choose 'open anyway'?
The following user(s) said Thank You: SoundSurfer
- SoundSurfer
- SoundSurfer
7 years 2 months ago #18729
by SoundSurfer
So I tried the following that did work:
right-click on the icon, and then while holding ctrl click on open. then you get the pop up with the security bullshit with the open anyway button..
so its sorted!
so its sorted!
- totoine
- Thank you received: 18
7 years 1 month ago #18744
by totoine
Replied by totoine on topic 4.1.03
Salut nico !
Quelques petites remarques après une petite semaine d'accueil sur un festival.
Version 4.1.0.3 sous windows 10.
- Quand j'ai un groupe chargé dans un SUB. Si j'éedite le contenu de ce groupe et que je réenregistre dans un nouveau groupe, le nom ne change pas dans la fenêtre principale.
- Si on double-clic sur la valeur d'un submaster, ça le met à FF. Mais si on re-doubleclic dessus, ça ne le remet pas à 0 ?
- Serait-il possible de pouvoir choisir une couleur par défaut ans le setup pour les sub (comme pour Registre et Prépa) ?
A bientôt.
A bientôt.
- leoclarys
7 years 1 month ago #18764
dble [=] le sub s'ouvre à FF
[=] le sub se ferme à 0
j'en ai profité pour changé l'indicateur de sélection des subs.
dorénavant quand un sub est sélectionné, c'est le bouton du numéro du sub qui passe en jaune, plus le tour du niveau
c'est quand tu utilises le raccourci @Level que ça fonctionne comme ça. pas à la souris (ou au dble-clic).- Si on double-clic sur la valeur d'un submaster, ça le met à FF. Mais si on re-doubleclic dessus, ça ne le remet pas à 0 ?
- Yugz
7 years 2 weeks ago #18858
by Yugz
Replied by Yugz on topic 4.1.03
Salut Nico
J'ai repéré un bug qu'il n'y avait pas avec la version précédente que j'utilisais (4.0.24).
Je suis passé à la 4.1.03 avec le même spectacle, le même contrôleur, le même boitier enttec et dans la même salle donc la comparaison est a priori fiable.
Mon système: MacBook Pro 2018 OS 10.14.6 - controleur midi: novation launchcontrol XL - boitier Enttec.
Voilà ce qu'il se passe:
Avec la baguette magique activée pour les subs, dès que j'active un sub en mode time depuis mon contrôleur, ça bug. Sur le moniteur d'activité, Dlight passe de 10% à 100% d'utilisation du processeur. Impossible de continuer lorsque ça se passe, il n'est alors possible que d'accéder aux fonctions dans FILE/DISPLAY/.../LICENSE, tout le reste est bloqué (commande GO etc.., monter un circuit à la souris, raccourcis clavier..). Il est quand même possible d'appuyer sur certaines touches mais ça ne fait qu'empirer les choses (par exemple appuyer sur GO, la touche se met en rouge mais rien ne se passe et l'utilisation du processeur passe à 200% environ (je ne comprend pas trop comment c'est possible en fait..).
Donc en gros il est juste possible de sauver ou de quitter mais en quittant ça reste sur la petite fenêtre blanche "working".
J'ai changer de port USB, changer de conversion USB, changer de contrôleur (mais avec un autre launchcontrol XL) et c'est toujours exactement le même bug.
Je peux éventuellement essayer avec un autre contrôleur plus tard pour voir si c'est pareil.
Cela n'arrive qu'avec des subs en TIME en note MIDI (pour allumer éteindre), les faders montent les subs sans que ça plante mais je remarque quand même une latence entre le fader et la montée ou descente du groupe (ce qui n'arrive pas quand la baguette magique est désactivée. Les autres notes (GO, GO BACK, PAUSE) n'ont aucun soucis.
Je peux envoyer une vidéo du bug si besoin.
Voilà j'espère avoir été assez clair dans mon explication.
Time to create page: 0.161 seconds
