4.0.18
8 years 8 months ago - 8 years 8 months ago #16173
4.0.18 was created by sl1200mk2
Here's landing
:Light 4.0.18
(special thanks to all guys who have tested and report during beta cycle)
available for almost every systems (Linux version will be uploaded ASAP... sorry guys for the looooong waiting).
it comes with a long list of new features and bug fixes... they're all listed here:
getdlight.com/wiki/index.php/ChangeLog
but here's a summary:
SLinks (pronounce Step Links).
-one can send custom Midi or OSC messages per sequence's step. Thus, it allows
:Light to become the master sequencer of your show as it can trigger specific cues/steps in other software.
-one can also load custom curves for output(s)/channel(s) on every steps of the sequence.
Patch:
-new 'quick select' option in order to select all outputs patched to selected channels
-new Channel/Output test shortcut
-speedUp display
Sample:
-smart +%/-% which only operate on recorded levels for selected channel(s) over a region or at one frame
Sequence:
-in the main sequence window, one can now arrange columns as desired
-new searchBox to quickly find a step/cue associated to a text
MasterLink/TimeLink/DeviceLink/StepLink Editor:
-one can now select active step
-more shortcuts
SubMaster Editor:
-one can now select active submaster
Curves:
-new design with more powerful editing
ShortCuts:
-new searchBox to quickly find a shortcut
Save/SaveAs:
-warning when directory is not writable
Force DeviceLink:
-one can now use FullForce new option and select which attributes will be recorded
Device:
-the main window should reflect active color for device. (it works for RGB or CMY colors only...)
General:
-selection style is now more obvious (yellow square is 'around' selected channels)
Palette Editor:
-one can move in Palette thanks to the new Up/Down switcher
Palette Listing:
-Colour Palette are now colored for EZ view
enjoy
:Light 4.0.18(special thanks to all guys who have tested and report during beta cycle)
:Light to become the master sequencer of your show as it can trigger specific cues/steps in other software.-one can also load custom curves for output(s)/channel(s) on every steps of the sequence.
-speedUp display
-more shortcuts
enjoy
Last edit: 8 years 8 months ago by sl1200mk2.
- leoclarys
8 years 8 months ago #16174
by leoclarys
Replied by leoclarys on topic 4.0.18
Merci pour toutes ces améliorations.
J'ai constaté un petit bug qui est également présent dans la 4.0.18 (OS 12.12)
Les textes dans les carrés des samples disparaissent quand je relance ma session et parfois quand je change de page. J'ai testé différentes façon d'écrire et ça se reproduit systématiquement, même si j'encode le texte dans la fenêtre sample.
Bonne soirée!
Léo
Bonne soirée!
Léo
- Morpho
8 years 8 months ago #16179
by Morpho
Replied by Morpho on topic 4.0.18
Petite question Nico concercnant la release note :
Palette Listing:
Les palettes sont sensées être colorées dans la fenêtre palette listing ? Pas le cas pour moi.
Dans la fenêtre principale c'est vraiment super d'avoir les couleurs sur les charnels des Device. (Même si j'utilise des 7x couleurs ca donne une idée)
Dlight c'est génial merci !
Palette Listing:
- Morpho
- Morpho
- bgoubert
- Thank you received: 22
8 years 8 months ago #16187
by bgoubert
Replied by bgoubert on topic 4.0.18
@nico
super les couleurs sur les palettes. Pour aller plus loin, tu crois que ce serait possible sur le main board display des palettes.
Autre petite question, il y eu dans le temps une fonction qui permettait de modifier les polices d'affichage, je l'ai recherchée et pas trouvée. Je me suis retrouvé avec un pc de dépannage avec un affichage beaucoup trop grand et donc aucune lisibilité. Y'a-t-il quand même un moyen de modifier cela.
Me reste à tester toutes les autres modifs pour encore plus de fun.
- Morpho
8 years 8 months ago #16190
Replied by sl1200mk2 on topic 4.0.18
c'est pas possible sur cette fentre car il peut y avoir plusieurs Device sélectionnés et chacun avec une couleur différente par Palette.
nope... ya plusAutre petite question, il y eu dans le temps une fonction qui permettait de modifier les polices d'affichage, je l'ai recherchée et pas trouvée.
- leoclarys
8 years 8 months ago #16197
by leoclarys
J'ai remarqué que l'affichage en valeur réelle dans la fenêtre Dlink ne fonctionne pas bien, à savoir pour 22 decimals dans le device command il m'affiche 5632 dans la fenêtre Dlink. Je te joins l'image.
Bonne journée!
Bonne journée!
- bgoubert
- bgoubert
