4.0.15 changelog
9 years 3 months ago - 9 years 3 days ago #15017 by sl1200mk2
4.0.15 changelog was created by sl1200mk2
- on Windows, you should now be able to double-clic on .sho in order to launch DL and load desire sho
- new SetUp I/O menu which group all DMX, USBDMX, NETDMX, MIDI and OSC function
*new option to cross-patch dmx universes
-DMX Input:
*more accurate
*new option to bound DmxInput to channels or SubMasters
-Patch:
*new option to "repeat" DMX Levels for Devices (useful for led strips)
- ArtNet :
*you can now manually register Node's IP/Net/SubNet.
*DL no longer send continuously packets.... it sends only on change.
- new option in the Setup "Release FREEZE on Go".
allow user to freeze DMX state until the next GO (useful when one want to move in sequence without modifying stage)
-Device Personality :
*you can now import Personalities of the OFL project (Open Fixture Library)
open-fixture-library.herokuapp.com/
(which at the time of writing is open-fixture-library-pr-199.herokuapp.com/ ).
*you can hide Commands for Colours, Focus and Blade in order to display bigger values table.
-Palette Editor:
*you can now use At_level shortcut on selection of levels (multiple selection is allowed)
-General
*you can now choose to display only patched channels
Last edit: 9 years 3 days ago by sl1200mk2. Reason: more things
