4.0.0_b57
10 years 8 months ago - 10 years 8 months ago #11799
4.0.0_b57 was created by sl1200mk2
available for MacOS systems... and 64bits Windows and Linux
getdlight.com/index.php/forum/2-releases...-pre-4-0-0-b57#11798
enjoy and shout
enjoy and shout
Last edit: 10 years 8 months ago by sl1200mk2. Reason: more OS
- Wilf
- Thank you received: 3
10 years 8 months ago #11802
Replied by sl1200mk2 on topic 4.0.0_b57
Hey Wilf,
I made a gig recently () with 15 devices and I realize some stuff can be better... so here's a new one :-)
main news are listed here:
getdlight.com/index.php/forum/2-releases/5782-pre-4-0-0-b57
- Wilf
10 years 8 months ago #11803
by Wilf
Replied by Wilf on topic 4.0.0_b57
Thnx, I used it. Still one thing that I don't know how to do, but maybe it's because I use video projection and the popups aren't moveable and stuck between the screens, unreadable. Thing is: I have a show with conventional lights, so I have 1 channel for multiple lights. Now more and more venues have LED but not always repatchable. So can I put one device (one channel) on multiple addresses somehow?
10 years 8 months ago #11804
I may have make things right... :whistle:
Normally, you can swap a traditional channel with a device.
Just open the device listing, import a device and set it a channel.
- Wilf
10 years 8 months ago - 10 years 8 months ago #11809
by Wilf
Ok, thanks. then I'll remake the show with multiple channels. More and more venues here are working with the ETC lights and with a standard light plan and do not want to change the addresses.
Last edit: 10 years 8 months ago by Wilf.
- bgoubert
- Thank you received: 22
- bgoubert
- celio
- Thank you received: 72
10 years 8 months ago #11812
by celio
Replied by celio on topic 4.0.0_b57
ça m'avait fait pareil sur la B56 mais je croyais que c'est moi qu'était un peu truffe
ce qui d'ailleurs ne veut pas dire que je ne le sois pas un peu quand même de temps en temps à la rigueur....
- bgoubert
- celio
10 years 8 months ago - 10 years 8 months ago #11831
au regard des noms que vous donnez à ce qui est chargé dans les subs, il y a un bug si vous passez par le sub lui-m^me.
si par exemple vous voulez nommer des groupes ou des chaze ou autre, faites le par les Listing, pas par les subs....
faut que je corrige ça....
Last edit: 10 years 8 months ago by sl1200mk2. Reason: orthographe
- bgoubert
- zenerve
- Thank you received: 6
10 years 8 months ago #11850
by zenerve
Replied by zenerve on topic 4.0.0_b57
Hey Nicolas, what was your setup on that Wampas gig ?
(In particular, what controller did you use?)
Care to share your .sho? I do have a hard time figuring out how to use moving heads live with DL.
Time to create page: 0.177 seconds
