- Thank you received: 2
Device personality
- Bestia Humana
This is the Martin Rush Par 2 RGBW Zoom personality.
Checked on stage. Dimmer fine is in EXTRA to control that.
Enjoy it
edu
congrats!!!!
you're the first
for the dimmer fine, this is not exactly how to do though...
There's a FINE attribut which you set to refer to the parameter you want.
In you case:
1st offset (attribut = INTENSITY), parameter = DIMMER
2nd offset (attribut = FINE), parameter = 1 (where 1 is the offset of the Intensity/Dimmer)
would you mind updating the personality, and after I'll publish it on the github
github.com/dlight-tools/dlight-devices
thanx,
- Bestia Humana
I did it this way at the begining but when I wanted to use it I was not able to find it to control it. It occurred to me to do it from EXTRA and it worked, I could control it .
It would be interesting in the future there could be a DIMMER or INTENSITY to control all of these issues.
It would also be interesting to change the values of different attributes using the keyboard. I was not able to do it. And as for the values of the attributes, we might choose to see them in DMX values (0-255) or percentage values. Especially for colors, because the values of the applications that I use to guide me are in percentage.
Thank you very much!!!!!
HASTA LUEGO!!!!!!
edu
WHEN THE MUSIC IS OVER
TURN OFF THE LIGHTS
If they're set, FINE are computed internally.
each parameters associated with a FINE can be controlled from the Device's attributes windows. except for the Dimmer...
so if you need to deal with this parameter, I've to figure out how to do...
nope, not for the moment.It would also be interesting to change the values of different attributes using the keyboard. I was not able to do it.
in the future it will be possible from the Device's attributes windows.
of course.And as for the values of the attributes, we might choose to see them in DMX values (0-255) or percentage values
will check that.
