4.0.0_b15
11 years 10 months ago #8967 by sl1200mk2
4.0.0_b15 was created by sl1200mk2
available for Windows, MacOS 10.8, 10.9, 10.10
bug fixes only...
please test and report.
The following user(s) said Thank You: nomatter
11 years 10 months ago #8994 by wikead
Replied by wikead on topic 4.0.0_b15
je reprend donc,
L'application ne répond pas sur MAcbook pro 13"
Tk_Init failed: no display name and no $DISPLAY environment variable
11 years 10 months ago #8995 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b15
@wikead
ça veut dire que la librairie graphique ne trouve pas le serveur X
t'as bien redémarré ton ordi après avoir installé XQuartz?
The following user(s) said Thank You: wikead
11 years 10 months ago #8997 by wikead
Apres un bon redémarrage, tout fonctionne
L'osc egalement ainsi que le Enttec pro
11 years 10 months ago #9025 by vbs
Replied by vbs on topic 4.0.0_b15
I am have a deleting que's and steps problem with Dlight3.24
If i delete que 4 tru 6 it ask do you want delete que 6???
If i delete step 7 it ask do you want delete que 6???
It shoo on the screenshots i uploaded
Also i like to work with al the commands on a separate program keyboard
If you delete you have to confirm yes or no …….Is there a short cut for or can it be made like enter enter ???
The go to step is in 0 sec while the fade time in the sequins is set on 5 sec.
can this also be altered in time, like go to step 5 time10
Recards Vincent
11 years 9 months ago #9050 by sl1200mk2
Hi Vincent,
it's strange because I thought I've answered you about this....
Delete cue 4 thru 6 is still not written, and it's part of what I will write for DL4
for enter shortcut, there's an ENTER command listed at the end of the shortcut window.
11 years 9 months ago #9097 by sl1200mk2
b16 update
Time to create page: 0.137 seconds
