3.0.24
12 years 2 weeks ago #8599 by sl1200mk2
3.0.24 was created by sl1200mk2
I'm proud to announce the 3.0.24 release of D::Light.
It's available for each supported platforms (macOS 10.6->10.9, windows, Linux 32b, Linux 64b).
- MacOS 10.6/10.7 build linked against XQuartz 2.7.4
- MacOS 10.8/10.9 build linked against XQuartz 2.7.5
NEWs:
here come the news....:
OLA:
on each supported platform (eg MacOS && Linux), OLA is up to date with their GIT repository
INHIBITION:
new concept for this function : from the main board, place the mouse on the channel's number (the white one), hold Shift and drag it to a submaster.
thus the submaster switch to INHIB mode and is loaded with a *non-editable* content that is called VOID.
you can load one or several channels.
it's intended to be a quick access to inhib function. the old method is still functional.
GENERAL:
windows size and position should adapt to current screen size
ARTNET:
with this release you can list and select 3D visualizer (Capture Polar for ex) as a node to stream DMX to it.
MIDI:
a confirmation is now asked when you click on the script button that set factory's connections.
some bugs have been adressed...
please report any suggestions/wrong behavior
also please consider making donations if you find the software usefull
Nicolas
The following user(s) said Thank You: azama
12 years 1 week ago #8601 by bgoubert
Replied by bgoubert on topic 3.0.24
@nico
Nouvelle inhib : Est-il normal que le n° de circuit inhibé n'apparaisse pas dans la fenêtre du submaster. Du coup si on veut faire plusieurs inhib différentes il est difficile de savoir lequel est lequel.
bruno
The following user(s) said Thank You: ignotus
12 years 1 week ago #8602 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.24
Salut Bruno,
le nouvel INHIB avec la définition VOID est plutôt une inhibition rapide en cas de pépin.
si tu veux bosser avec des inhib préparées, mieux vaut se servir de l'ancienne méthode:
on met un sub en mode INHIB un sub qui contient un STOCK x.
12 years 1 week ago #8603 by azama
Replied by azama on topic 3.0.24
Bonjour Nicolas,
Merci pour cette nouvelle version.
J'ai un message d'erreur au démarrage qui empêche le lancement de DLight:
Error: invalid command name "center_the_top_level".
J'avais également cette erreur dans la version précédente de DLight.
Je suis sous Windows Xp mais je peux tester sous Win7 et Windows 8 pour voir si c'est pareil.
12 years 1 week ago #8604 by sl1200mk2
@azama,
c'est bizarre ça....
je garde spécialement un win32 pas trafiqué pour checker que tout fonctionne et ici ça se passe bien....
voyons voir ton installation:
tu lance l'installateur.
il te demande si tu veux enregistrer le programme dans C:\Program Files(x86)\DLight3.0.24 (tu réponds oui)
il te demande si tu veux créer un shortcut (tu réponds oui)
ça se passe comme ça chez toi?
12 years 1 week ago #8605 by azama
Donc j'ai désinstallé puis ré-installé en laissant les choix par défaut.
A présent cela fonctionne. :lol:
Je pense que le problème venait du fait que j'avais installé DLight dans le dossier suivant:
C:\Program Files\[] Midi-Dmx\
Et que les crochets posaient problème dans le nom du dossier.
Merci !
12 years 1 week ago #8606 by sl1200mk2
@azama,
bonne analyse ;-)
12 years 1 week ago #8607 by bgoubert
@nico
un truc bizarre sous mac 10.9.5 tous les shortcuts que j'avais enregistré en minuscule ne marchent plus qu'en majuscule. c'est d'ailleurs le cas pour toutes les frappes, ça fait la même chose pour le texte, il faut que j'inverse.
j'essaie avec mon ancien mac en 10,5 et te tiens au courant.
bruno
12 years 1 week ago #8608 by bgoubert
@nico
essai avec mac 10,7 ça ne le fait pas, tout est en ordre. version XQuartz 2.7.7
bruno
12 years 1 week ago #8609 by bgoubert
le nouveau mac est XQuartz 2.7.6 j'essaie avec la mise à jour 2;7;7
bruno
12 years 1 week ago #8610 by sl1200mk2
@bruno,
alors? ça donne quoi?
12 years 1 week ago #8611 by bgoubert
@nico
tout marche bien avec x6, x7 sur Mac 10.7.5 et est inversé sur 10.9 avec X8 X9
bruno
12 years 1 week ago #8612 by sl1200mk2
avec des XQuartz identiques?
12 years 1 week ago #8613 by bgoubert
@nico
yes,sir.
12 years 1 week ago #8614 by sl1200mk2
:huh:
bizarre, ici ça fonctionne bien...
tu pourrais installer un xquartz 2.7.5 (c'est celui avec lequel est linké DL) pour voir?
Time to create page: 0.172 seconds
