3.0.19_b3
12 years 9 months ago #7372 by sl1200mk2
3.0.19_b3 was created by sl1200mk2
bug fix.
thanx for your tests.
12 years 9 months ago #7375 by vbs
Replied by vbs on topic 3.0.19_b3
Hi
I see that the Inhabitation display is not there any more?
In the version 3.18 it was still there but he when you set a channel in inhabitation it was not visible in the display.
Regards Vincent
12 years 9 months ago - 12 years 9 months ago #7376 by colinc
Replied by colinc on topic 3.0.19_b3
@Vincent
The way inhibition works has changed, so the old inhibition window has gone. Now, you select some channels you want to inhibit, create a group with them, and then attach that group to a submaster. In the FLASH/TIME selector for the sub, you will now see a third option - INHIBIT. If you make that submaster an IHIBIT submaster, then wnen it is at FULL, any live channels in eg, the sequence window, which are part of the INHIB group will have their output proportionately reduced. See the thread on Inhibition in the 'Main' forum.
Regards,
Last edit: 12 years 9 months ago by colinc. Reason: removed html
12 years 9 months ago #7377 by vbs
Hi Collin,
Great This is a fine improvement!!!!!!!
Thanks
Regards Vincent
12 years 9 months ago #7383 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.19_b3
Hi,
does anyone have problems installing this beta on a windows 8.1 computer?
thanx,
12 years 9 months ago #7394 by vbs
Today i notice that if you have the desk in @Mode and you want to record a cue it don't record it.
For instance que - 4.1 - rec - enter Noting is happening
In RPN mode it works and you see it is recorded
Regards Vincent
12 years 9 months ago #7395 by sl1200mk2
in @Mode, the sentence is [REC] 4.1 [ENTER]
12 years 9 months ago #7396 by sl1200mk2
does anyone have a friend with win8.1 to test installation of the latest beta?
12 years 9 months ago #7398 by vbs
is this a little confusing in the @mode
To update the cue i can use 4.1 [update] [enter]
If i want to rec a que the i aspect to start with the [cue] or 4.1 than [rec]
12 years 9 months ago #7399 by sl1200mk2
:huh:
what is [UPDATE]?
when I try to modify:
[MODIFY] x [ENTER] -> modify the cue x
[REC] x [ENTER] -> record the cue x
[MODIFY] [ENTER] -> modify the cue in the activ' register
x [MODIFY] [ENTER] -> modify the cue in the activ' register
don't you have the same behavior?
Time to create page: 0.179 seconds
