3.18 Can not edit text in sequence
12 years 10 months ago #7308 by vbs
Hi
I noticed that if i want to change text in the sequence menu i get a error.
I double click in the text area and a error disappears. Wrong:#args:…………...
I added a screenplay from it.
Further i like to make a comment about the patching.
I would be handy if you can scroll down in the patch field and by double click to the dimmer you want you make the dimmer active.
Now you have to click on the little arrow many…..many time if you want to go from dimmer 12 to 278 for instance.
Is there a possibility for the next update to change this ???
Thanks Vincent
12 years 10 months ago #7309 by sl1200mk2
Replied by sl1200mk2 on topic 3.18 Can not edit text in sequence
Vincent, sequence error is fixed for the next release.
For the patch, why don't you use shortcuts?
Time to create page: 0.125 seconds
