3.0.17
12 years 11 months ago #7153 by sl1200mk2
3.0.17 was created by sl1200mk2
la belle lurette...
I'm proud to announce the 3.0.17 release of D::Light.
It's available for each supported platforms (macOS 10.6->10.9, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
OLA
- OLA server has been updated
USB DMX
- libusbx has been updated
- Espion2 from Robert Juliat can now be used to output DMX
- USB DMX Pro MK2 from Enttec can now be used and output DMX on 2 universes
- ultraDMX Pro from DMXKing.com can output DMX on 2 universes
ROOM/DMX UNIVERSE:
- now D::Light use 1.1 for the first universe/room and 1.2 for the second, 1.3 and 1.4
OSC:
- more OSC messages
LOOP:
- new function that allow to set the number of times that a FX or a Sample is looping.
available in Submasters as well as in MLinks.
MIDI TIME CODE:
- you can control all the STEPs *not the cue's* thanks to a midi clock.
MIDI:
- fix crash for loooooong midi patch, that leads to a "Midi Channel 2 display" selector.
FX:
- you can now import Cue from the sequence or recorded Groups in the FX Editor
GROUP:
- you can now record only selected channels as GROUP. a pop-up window ask 4 your choice.
lots of work on this one...
many many thanx to every people that have spend some times during the beta process.
Enjoy and consider making donations if u find this software useful.
Nicolas
The following user(s) said Thank You: quico, Jefff, loupiotes, bashaut
12 years 11 months ago #7157 by loupiotes
Replied by loupiotes on topic 3.0.17
12 years 11 months ago #7158 by muzikmateo
Replied by muzikmateo on topic 3.0.17
Bonjour
Quels sont les nouveaux messages osc dispo ?
12 years 11 months ago #7159 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.17
/seq/X1ActiveCue
/seq/X2ActiveCue
/patch/RoomUniverseRQ (Room, universe request)
/patch/displayActiveRoomUniverse (display active universe / room)
/patch/styleRoomUniverse (display room or universe)
les plus récents étant tout ceux de la précédente version:
www.nicole-banana.com/index.php/forum/2-releases/5133-3-0-16
12 years 11 months ago #7182 by Wilf
Replied by Wilf on topic 3.0.17
In this release I have some problems with patching:
- The dimmer and channel text fields (where the numbers are) are now grey in stead of white and I cannot change them by typing anymore. It now takes me forever to go from dimmer/channel 1 to dimmer/channel 455.
- Sometimes typing does not register. I can type [CH} or [DIMMER] but the number will not follow.
- Sometimes, when working with two universes and patching them the patch page becomes unresponsive and the patchfield becomes completely white.
Besides this I have a wish for patching: It would be great if it would be possible to patch multiple dimmers on one channel that are not in a row, like this:
[CH]XX[@][DIMMER]YY[+]RR[+]VV
So one could, for example, patch channel 50 to dimmer 20, 55 and 123.
12 years 11 months ago #7183 by colinc
Replied by colinc on topic 3.0.17
Same issues here
12 years 11 months ago #7184 by petit.did@free.fr
Replied by petit.did@free.fr on topic 3.0.17
Bonsoir,
D Light téléchargé et installé plusieurs fois sur mac OS 10.6.8.
Quand je le lance je n'ai que X11 qui tourne D Light ne démarre pas.
Une idée de ce qui se passe.
J'ai simplement glissé l'Icône dans le répertoire applications comme d'habitude, sans avoir désinstallé la version précédente.
Merci de votre réponse.
12 years 11 months ago #7188 by Jefff
Replied by Jefff on topic 3.0.17
Peut-être aussi un problème avec le "drapeau" qui permet de n'afficher que les circuits actifs, impossible des fois de revenir à tous les circuits visibles (de 1 à 60 par exemple).
12 years 10 months ago #7221 by sl1200mk2
I will post a 3.0.18_b2 tomorrow that should address the issues you mentioned.
12 years 10 months ago #7227 by sl1200mk2
3.0.18 is online
ps@Jeff
c'est pas un drapeau c'est une baguette magique....
12 years 10 months ago #7229 by Jefff
je pensais que c'était une manche à air finalement, ça y ressemble un peu non ? :-)
Sinon, il y a une màj 2.7.5 de xquartz, ça a l'air de tourner avec la .18.
12 years 10 months ago - 12 years 10 months ago #7271 by petit.did@free.fr
Une fois la dernière version de XQuatrz installée plus de problème. Version 3.0.18 Ok. :woohoo:
Last edit: 12 years 10 months ago by petit.did@free.fr.
12 years 10 months ago #7273 by Jefff
j'ai reçu dans ma boite gmail le message de petit.did ci-dessus. Ce qui est normal, mais par contre le message reçu est celui-là :
"Une fois la dernière version de Xflash installée plus de problème. Version 3.0.18 Ok. :woohoo:"
Je suis étonné du "Xflash".. quelqu'un comprend pourquoi ?
(Je sais ça n'a rien à faire ici.... sorry... mais bon j'comprends pas...)
12 years 10 months ago #7274 by petit.did@free.fr
Message corrigé remplacé Xflash par Xquartz dans la foulée Excuses...... Validé trop tôt le message :blush:
12 years 10 months ago #7275 by Jefff
Ah ok, j'en étais à me faire des idées sur le traitement des données perso de gmail !
Time to create page: 0.195 seconds
