3.0.17_b6
13 years 4 days ago #6869 by sl1200mk2
3.0.17_b6 was created by sl1200mk2
a release candidate.
available for all supported platforms, Linux 32&64 bits, Windows, MacOSX 10.6, 10.7, 10.8
it should work on MacOSX 10.9
news :
USB DMX PRO MK2:
DL can now output on the 2 universe of the new widget from Enttec
MIDI:
fix a bug when Midi map are huge. There's now a "Midi Channel 2 display" selector.
please test heavily and report.
Nicolas
13 years 3 days ago - 13 years 3 days ago #6874 by vbs
Replied by vbs on topic 3.0.17_b6
Hi
I see for a long time the Inhibitation Editor in Dlight but i can not find out wat i can do with it.
Can you help?
Regards Vincent
Last edit: 13 years 3 days ago by vbs.
13 years 3 days ago #6876 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.17_b6
Hi Vincent,
when you register a channel in the inhibition editor @FF, the channel will be blocked until you de-register it.
if you set a level to this channel, 80% for example, all level for this channel will be output at 80% of the recorded levels. in this case it's a scale.
did you understood the 1.1 and 2.1 in the patch editor?
13 years 1 day ago #6892 by Jefff
Replied by Jefff on topic 3.0.17_b6
J'ai des clignotements quand j'utilise l'osc, comme des micros chutes de tension, cela persiste après l'arrêt d'envoi de données vers dlight. Une fois l'osc en position OFF tout redevient normal.
je suis sur la 3.0.17_b6 sur mac
13 years 1 day ago #6893 by Jefff
Erreur de ma part, coincidence... c'est toute l'arrivée électrique qui avait un problème...
Sorry !
13 years 6 hours ago #6895 by vbs
Hi
Is there a way of clearing the inhibition editor ?
Deleting the channels again?
Regards Vincent
12 years 11 months ago #6900 by sl1200mk2
@Vincent
x ch 0 @_level
remove channel x from the inhibition editor, like 0 [TIME] in the timegroup editor.
12 years 11 months ago #6904 by Wilf
Replied by Wilf on topic 3.0.17_b6
I always clear the inhibition for the next day this way: "[CH] 1 [THRU] 512 @ 0" and then enable the change.
After that I push twice on the backspace button to clear the visual screen.
12 years 11 months ago #6930 by friedrick
Replied by friedrick on topic 3.0.17_b6
bonsoir,
cette version plante au démarrage sur mon os 10.5.8
et question, as tu intégré l'utilisation de projecteur LEDS ?
Fred
12 years 11 months ago #6938 by sl1200mk2
@friedrick,
cette version demande 10.6 au minimum, elle ne fonctionnera donc pas sur 10.5
pour les projos à LED, je finalise la 17 et après je m'y colle.
12 years 11 months ago #6941 by friedrick
merci pour l'info, va falloir que j'upgrade mon os.
bon développement
12 years 11 months ago #6953 by ouzadia
Replied by ouzadia on topic 3.0.17_b6
je ne sais comment télécharger DLIght 3.0.17?
12 years 11 months ago #6956 by sl1200mk2
la 3.0.17 n'est pas encore publique.
DL fonctionne par cycle de beta avant la release, release que j'espère publier bientôt
The following user(s) said Thank You: balgrim
12 years 11 months ago #7064 by sl1200mk2
b7 is online
Time to create page: 0.189 seconds
