3.0.17_b3
13 years 4 weeks ago #6719 by sl1200mk2
3.0.17_b3 was created by sl1200mk2
there will be a b4 before the release as libusbx team have provided an update but the guy that have a 10.6 systems in order to compile it (I do not have this system anymore...) is on a boat right now....
for the windows system, i've forgot to update it...
linux package are up to date.
news:
* new OLA 0.8.31 release included in OSX & Linux package.
* new LOOP command for FX and Sample loaded in submasters (also available in MLink)
* new LOOP shortcut available for MLink and Submaster's editors
enjoy and report any wrong behaviour.
report also any satisfaction ;-)
13 years 4 weeks ago #6724 by reitrop
Replied by reitrop on topic 3.0.17_b3
Bonjour Nico
Quel est le raccourcis clavier pour les boucles (LOOP) dans le "MasterLink Editor" ?
Pour info : je place dans chacun de mes FX en STEP 0 (une FXcue vide et toute les valeurs T & D à 0)
Cela stabilise le FX dans tous ces fonctionnement.
13 years 4 weeks ago #6725 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.17_b3
celui que tu vas assigner dans la fenêtre d'édition des raccourcis.
13 years 3 weeks ago #6729 by sl1200mk2
des news quand aux nouvelles fonctions?
13 years 3 weeks ago #6745 by colinc
Replied by colinc on topic 3.0.17_b3
sl1200mk2 wrote: des news quand aux nouvelles fonctions?
Salut Nico
Observed...
'Loop' function -
With FX attached to SUB: With eg: 1 Loop selected ; click on SUB button (Or press related F# Key) - FX runs once; click SUB button again - FX runs once again; ad infinitum... ; So - Behaviour as expected.
With SAMPLE attached to SUB: With eg: 1 Loop selected ; click on SUB button (Or press related F# Key) - SAMPLE runs once; click SUB button again - NOTHING HAPPENS... click SUB button AGAIN - SAMPLE *now* runs once again; click SUB button again - NOTHING HAPPENS... click SUB button AGAIN - SAMPLE *now* runs once again; ad infinitum... ; So - Behaviour un-expected?
Otherwise, bravo...
LED's coming soon...? :whistle:
Regards,
13 years 3 weeks ago #6748 by sl1200mk2
@Colin,
hey you, glad to read you again ;)
I'll try the behavior you've exposed and try to find what's wrong.
Otherwise, bravo...
thanx, it was a long awaited function.
I can improve it with reverse mode or thing like that but this one is nice.
for now, I'm dealing with Midi TimeCode in order to control DL from an external timer.
I don't know if many people will use this very much but it can be a good point.
I need to publish another beta with the libusb update
after that the 3.0.17 will be public.(I hope in October)
after that, Led and moving lights will raise
this is the plan....
13 years 3 weeks ago #6761 by sl1200mk2
@Colin,
do you observe this behavior only with Timed Sub, or also with Flashed Sub?
13 years 2 weeks ago #6765 by colinc
Hi Nico...
sl1200mk2 wrote: @Colin,
I originally only tried it on Timed Sub. So I just tested in both Timed and Flash modes
For FX - BOTH modes work correctly
For SAMPLE - FLASH mode works every time ; TIMED mode has the 'every other click' that I originally reported
Best,
13 years 2 weeks ago #6767 by sl1200mk2
@Colin,
fixed for the next beta.
thanx for testing/reporting
13 years 2 weeks ago #6786 by sl1200mk2
new beta is online.
