3.0.15_b10
13 years 5 months ago #6412
3.0.15_b10 was created by sl1200mk2
let's Go!
should fix some Midi issue with SysEx connection.
should fix OLA server loading
should fix libusbx issue on MacOSX
please give a shot and report.
Nico
Nico
- pancho
- Thank you received: 12
13 years 5 months ago #6421
by pancho
Replied by pancho on topic 3.0.15_b10
Tout roule chez moi, du moins ce que j'ai testé, sur os10.6 et linux64.
ola et midi sysex impecc'.
- pancho
13 years 5 months ago #6423
by pancho
nickel!
13 years 5 months ago #6424
Replied by sl1200mk2 on topic 3.0.15_b10
ok, thanx.
je vais donc effectuer une dernière batterie de tests et publier la 15.
- noelvd
- Thank you received: 4
13 years 5 months ago #6430
by noelvd
Replied by noelvd on topic 3.0.15_b10
Another minor :
When saving a show as ASCII, it puts 'SUBMASTERSWITCH' twice. I guess the second one should be MIDISWITCH.
Best regards,
Noël
Code:
! SETUP
SET $SHOWNAME Studio_1
SET $SHOWCHANNEL 512
SET $STEPNUMBER 25
SET $GOBACKTIME 5
SET $DEFAULTTIME 5
SET $DEFAULTAUTOLEVEL 255
SET $MYCOLOR #002b1e
SET $GRANDMASTERLEVEL 255
SET $WAITINHIB 0
SET $AUTOLOADCUE 1
SET $STEPPERCENT 13
SET $MYDMXOUTPUT 1
SET $OSCPROCESS 1
SET $SUBMASTERSWITCH 1
ENDDATA
Noël
13 years 5 months ago #6437
@Noel
Midi is not parsed for ascii files.... ascii is an incomplete task.
but you're right there should not be 2 x SET $SUBMASTERSWITCH 1 line.
thanx,
thanx,
