3.0.15_b6
13 years 6 months ago #6231 by sl1200mk2
3.0.15_b6 was created by sl1200mk2
available for MacOS >= 10.6 && Windows
with the previous one, it could happen that the patch was not recorded ->fixed
news:
in the Midi Patch, when you select a channel for a connection, you can specify the ROOM it belongs.
happy testing!
ps:
I plan to release the 3.0.15 by the end of the next week (if everything goes well).
13 years 6 months ago #6245 by noelvd
Replied by noelvd on topic 3.0.15_b6
b6 download, on the Mac Mini with OS X 10.6.8.
Tested the new features in the Patch-window.
Works as designed :)
Also noticed that export (of the patch) to XML, now writes 'rooms', instead of 'universes'.
Good job !
Wll do more testing (multiple universes -live- in one room) in the next few days.
Best regards,
Noël
B)
13 years 6 months ago #6252 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.15_b6
thank you Noel for the tests.
I've pushed a b7 with different code to handle usb widget connections.
as it's expected to work on 32b computer as on 64 and you're the only one with this kind of material (and as you're active on the tests ;-) ), can you try the DMX connection on your MacMini? (and reply in the b7 thread).
Nico
13 years 6 months ago #6253 by noelvd
sl1200mk2 wrote: thank you Noel for the tests.
Nico
Will download b7 ASAP, and test.
But remember that I have an ArtNet node, not a USB-DMX interface.
Best regards,
Noël
B)
13 years 6 months ago #6254 by sl1200mk2
damned!!!!!
13 years 6 months ago #6255 by noelvd
sl1200mk2 wrote: damned!!!!!
Sorry :(
But look at the bright side : with the ArtNet node (electron design), I can test up to 4 universes in 1 room.
Working on getting the cabling done for that.
Will report the result.
Best regards,
Noël
B)
P.S. Second BCR2000 ordered :)
13 years 6 months ago #6256 by sl1200mk2
by the way, do you work in a theater or do you got a theater?
13 years 6 months ago #6258 by noelvd
sl1200mk2 wrote: by the way, do you work in a theater or do you got a theater?
Yes, I work in the biggest theatre in the world: the Internet. :laugh:
(I'm a telecom engineer)
No, actually I have been doing light for theatre and bands for many years (freelance, in the weekends), but stopped when I got married.
Now that my children are getting bigger, I picked up my old hobby.
I don't have a lot of light fixtures, but I have.many different fixtures : some Par56 LEDs, 2 mini moving heads, 4 Martins 812, and a Revolution III -which needs 256(!) channels, all -soon- connected to 4 universes on an ArtNet node.
And of course a BCF2000, a BCR2000 (soon 2), an iPad, and an iPod, which can all be used to control DL :)
You've seen the pictures of the "BigDesk" (3-4 BCF2000, 2 BCR2000, and the Mac Mini inside) that I'm hoping to build one day.
I have looked at other DMX-software, and I like yours the best..
Keep up the good work ;)
Best regards,
Noël
13 years 5 months ago #6266 by sl1200mk2
@Noel,
glad you enjoy DL ;-)
may I ask you one thing:
did you tried OLA DMX server included in DL?
it would be nice if we can make some tests on both 32 & 64 bits machine before the release.
13 years 5 months ago #6267 by noelvd
Bonjour Nico,
I'll see what I can do, but I will be very busy for the next 2 weeks, so it may take a while.
What exactly do you want me to test with the OLA DMX server ?
Best regards,
Noël
B)
13 years 5 months ago #6268 by sl1200mk2
no problem if you cannot do that now...
what I would like you to test is mainly activation on both 32&64 bits machines (Setup/Dmx/OLA Server).
13 years 5 months ago #6269 by noelvd
Nico, OLA Server = ArtNet Server ?
In that case, I can confirm that it works fine on the Mac Mini (see 3.0.15_b7 threat).
Best regards,
Noël
B)
13 years 5 months ago #6270 by sl1200mk2
nope, OLA is a multi-protocol server (wich of course include artnet).
to use it you need to choose OLA instead of ARTnet in the Setup of DL.
Time to create page: 0.161 seconds
