3.0.15_b5
it should correct wrong behaviors.
just a quick news, in the midi window, when you use the 'recycle' function to load Midi part, DL should point to the corresponding connection if it exists.
Thank you for reporting!
Nico
- colinc
- Thank you received: 22
Installed 3.0.15_b5
sl1200mk2 wrote: 3.0.15_b5 is online.
@Colin
several tentative with new libusb-1.0.dll are all successfull on different machines.
each time, zadig ask me to replace drivers from FTDIUSB to WINUSB, and after a reboot, I can access to ultraDMX Micro.
so the 3.0.15_b5 include the new libusb.
merci de répondre dans le thread de la 3.0.15_b5
Ok, so I...
1) Control Panel -> Device Manager -> Universal Serial Bus Devices -> USB Serial Converter -> Uninstall Driver -> Disconnect DMXMicro
2) Reconnect DMXMicro -> Windows reinstalls FTDIBUS driver (Check it's connected by running eg QLight Controller
3)Run Zadig.exe (Latest version 2.0.1.160), and re-install WinUSB (v6.1.7600.16385)(libusbx)
4) Reboot
5) Run DLight - 'USBDMX not found' - clicking red light doesn't connect - also, the 'progress' window in dlight (top right) says 'libusb_open() failed'
6) Select ArtNet instead of USB - artnet discovers eg iPad ok, etc
7) Reselect USBDMX - 'not found, and no connection
:S
- pancho
- Thank you received: 12
attached a libusb-1.0.dll
can you please unzip it, copy it in the bin folder and try again.
this is odd,2) Reconnect DMXMicro -> Windows reinstalls FTDIBUS driver
why do you let windows reinstall drivers?
Nico
- Barrillet
Désolé mais pas d'améliorations notables, en changeant ma conduite son sous Ableton Live je réussi a faire a peu près ce que je veux par contre
Merci d'avoir bossé dessus, mais ça a l'air un peu compliqué non? :blink:
ça veut dire qu'à 10ms dès que ton sub passe par 0 il ne remonte pas après?
ouais c'est balaise....Merci d'avoir bossé dessus, mais ça a l'air un peu compliqué non?
- Barrillet
J'ai trois sub qui s'enchainent, en MIDI controlées pas Ableton Live. J'ai modifié les courbes MIDI pour avoir une montée treees progressive et assez lente. Parfois le signale est bien pris en compte, parfois non...
et ça, ça devrait pas....Mouais bon, en fait c'est bizarement compliqué, parfois ça marche, parfois ça marche pas.
ça devrait être une horloge....
à quelle vitesse t'arrive à avoir des bons résultats?
ça à rien à voir avec l'alarme dont tu parlais si?J'ai trois sub qui s'enchainent, en MIDI controlées pas Ableton Live.
parce que ça c'est peut-être le symptôme d'un autre bug...
peux-tu décrire comment tu fais pour 'enchainer' tes trois subs? et à quelle vitesse?
- Barrillet
L'alarme c'est bon. Avec tes modifs et les miennes ça remarche (j'ai réduit le nombre d'infos midi)
Pour l'autre : En fait sur une chanson j'ai 5 subs en tout :
2 Subs qui font un "chaser" : Un qui clignote sur les aiguës, un autre sur les bass. Un plugin me transforme le son en info midi.
3 Subs qui s'enchainent a la fin sur une batterie (ambiance One Man Show, désolé...). Chacun des Subs reste 2 secondes en place en gros.
Les 2 premiers fonctionnent bien, les 3 autres ont du mal a s'enchainer. La solution que j'ai trouvé c'est de mettre une jolie courbe sur le midi pour qu'il n'y ai qu'un seul Sub envoyé a la fois. Ca marche, mais du coup c'es compliqué de superposer plusieurs Sub avec cette méthode.
Bref je bosse dessus pour trouver la meilleur méthode, ça devrait finir par marcher, et puis je doute que l'oeil de Madame Michu fasse la difference entre un enchainement de 100ms et 10ms
est-ce que tu peux re-essayer en remettant les infos Midi à blinde _ en gardant la résolution de 10ms pour voir si ça passe.L'alarme c'est bon. Avec tes modifs et les miennes ça remarche (j'ai réduit le nombre d'infos midi)
donc ce que tu dis c'est que si t'envoies 2 infos midi en même temps (sur le même canal(?) et avec numéro de CC différents j'imagine), DL n'en prends qu'une des deux? t'es donc obligé d'envoyer des infos Midi pour qu'il n'y ait qu'un seul déclenchement à chaque fois.Les 2 premiers fonctionnent bien, les 3 autres ont du mal a s'enchainer.
tu peux joindre un MidiMon de cette commande multiple?
- Barrillet
2 log : Un qui ne fonctionne pas, trop d'info, l'autre qui fonctionne pile poil (si j'augmente la frequence sur celui ci ça ne fonctionne plus)
Attachment Sirene.zip not found
- Barrillet
Tout les subs sont sur le même canal, en fait j'avais un Sub qui ne s'arrêtait jamais il envoyé du coup j'en avais en permanence 2 en route, plus un 3eme au moment des chevauchement. En virant celui ci ça marche.
En résumé : 2 subs en même temps Ok.
3 : Pas boooon
EDIT
Les subs sont sur le même Channel, mais avec des CC différents.
attends je me suis peut-être gouré dans la lecture du MidiMon...
10:59:52.677 From Bus IAC 1 Control 5 0 1
10:59:52.678 From Bus IAC 1 Control 5 0 0
l'intervalle entre les deux c'est pas 10ms mais 1ms non?
je peux te garantir un fonctionnement à 10ms, mais à 1ms, non.
c'est quand même con si on peut pas envoyer 3 Subs, non?
mais ça m'étonne....
rephrasons (
Live envoie une info Midi a un instant t qui lève un sub. le sub est levé et tourne.
Live envoie une info Midi a un instant t+x qui lève un sub. le sub est levé et tourne, ça fait 2 subs qui tournent.
Live envoie une info Midi a un instant t+y qui lève un sub, et là c'est le drame, le sub ne veut pas se lever.
