3.0.12
13 years 6 months ago #5906 by sl1200mk2
3.0.12 was created by sl1200mk2
écran total...
This is the douzième patch of the 3.0 series of D::Light.
It's available for each supported platforms (macOS 10.5->10.8, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
Please be aware that this should be the last available release for Windows XP systems.
Please be aware that this should be (as usual) the last available release for MacOX 10.5 systems.
but this time, I mean it.
thank you for everyone who helped during the beta process.
news:
General:
- New 'Scene Master' (control via OSC (/seq/master xxx) and Midi). Allow to dim channel's that have a level in the active working register.
- DMX Universe / Channels Universe have been cleaned... here comes 'ROOMs' for channel.
that mean that 1 Room = 512 channels, 2 Room = 1024 channels, etc...
MIDI:
- Master (eg AllSubMaster, FlashMater, GrandMaster, SceneMaster, Joystick) have now their levels exported.
- You're now able to select between several Input/Output
- Channel's level are now exported to Midi Out.
- New 'Script' button to load a default Midi Patch
OSC:
- You're now able to use several IP/Port as output.
Time:
- You can now set 0.01 as time for xfade, wait, etc...
Sample:
- There's no need to set a time length to record a sample. just push the button (elapsed time is displayed) and stop it when you want. a maximum of 1 hour can be recorded.
Shortcut:
- standard shourtcuts now include &é"'(§è!çà as 1234567890
ChannelTrack:
- Better behavior when a lot of channels are loaded.
and several bug fixes, enhancements, etc...
If you appreciate the software, please consider making donations.
Enjoy.
Nicolas BATS
The following user(s) said Thank You: pipou
13 years 6 months ago #5909 by colinc
Replied by colinc on topic 3.0.12
Salut Nico
Can't open any existing .sho files
get:
13 years 6 months ago #5910 by celio
Replied by celio on topic 3.0.12
salut nico
de mon coté l'installation se fait normalement mais impossible de lancer la nouvelle version de dlight.
il lance x11 mais ne lance jamais dlight...
bonne journée
célio
13 years 6 months ago #5911 by celio
coucou re
je viens juste de voir qu'il fallait xquartz
je réessaie et m'excuse du post d'avant
re bonne journée
célio
13 years 6 months ago #5912 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.12
woops :huh:
making x-platforms stuff is not the simplest task...
I've a fix and will publish the 3.0.13...
thanx for noticing
13 years 6 months ago #5914 by sl1200mk2
@Colin,
b4 telling the world, would you mind trying the 3.0.13?
Nico
13 years 6 months ago #5915 by boeckel
Replied by boeckel on topic 3.0.12
J'ai pas encore eu le temps de l'essayer, mais bravo d'avoir pu intégrer toutes ces fonctionnalitées.
13 years 6 months ago #5921 by colinc
sl1200mk2 wrote: @Colin,
Nico
Same problem with 3.0.13
Time to create page: 0.181 seconds
