3.0.12_b2
- when you record a cue in X1, if scene master's level is not FF, it's reseted to FF
- all the scroller (eg AllSub, Scene Master, FlashMaster, Joystick and GrandMaster) have their values exported to midi/osc out (please try that _ with motorised fader it would be great)
-new usbPro code
Nico
- colinc
- Thank you received: 22
sl1200mk2 wrote: - sceneMaster now modulate level's channel display
Yes
sl1200mk2 wrote: - when you record a cue in X1, if scene master's level is not FF, it's reseted to FF
Yes
sl1200mk2 wrote: - all the scroller (eg AllSub, Scene Master, FlashMaster, Joystick and GrandMaster) have their values exported to midi/osc out (please try that _ with motorised fader it would be great)
I have no motorised faders, but when I test the output for any of those masters inBome's SendSX, they output a non-stop stream of MIDI messages of whatever level is set. Should that be so? (Do motorised faders need a non-stop stream to maintain their level, or should DL just output the MIDI message one) For example, if I control a single sub from 0 to FF from my BCN44, it outputs like this
B2 18 7F
B2 18 23
B2 18 1C
B2 18 17
B2 18 11
B2 18 06
B2 18 00
B2 18 00
(ie once for each increment in level it catches)
whereas when I connect the Scene Master to it, it outputs like this
ad infinitum
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
B0 5E 66
ad infinitum
until I change to a new level, and then that level runs 'ad infinitum'
sl1200mk2 wrote: -new usbPro code
Nico
Regards
nope this is a bug.they output a non-stop stream of MIDI messages of whatever level is set. Should that be so?
does the submaster that have a midi bind export their values?
can you monitor that, please?
- colinc
From my previous post -
... if I control a single sub from 0 to FF from my BCN44, it outputs like this (Sub 1 on MIDI Ch 3 CC 24 00-FF)
(SendSX has initial value at the bottom)
B2 18 7F
and so on up to...
B2 18 23
B2 18 1C
B2 18 17
B2 18 11
B2 18 06
B2 18 00
B2 18 00
so as the encoder is turned, it outputs increasing (or decreasing) values (the figures above are actual copy/paste from SendSX, (with some cut out of course)). Because I was turning the encoder fast, sendSX wasn't capturing every single value as you can see - but the Subs values in DLight could go to exactly where I wanted if I was careful enough. So yes, Subs export their values.
