3.0.11 Release
13 years 8 months ago #5487
3.0.11 Release was created by sl1200mk2
Haute Couture!
This is the eleventh patch of the 3.0 series of
:Light.
It's available for each supported platforms (mac0S 10.5->10.8, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
Please be aware that this should be the last available release for MacOX 10.5 systems
thank you for everyone who helped during the beta process.
news:
General:
- many improvements in the internal code.
- reverse to 20ms for the DMX output rate
DMX:
- OLA server has been upgraded to 0.8.26
Scroller:
- added 'Live' mode to scroller and fix several bug
Shortcuts:
- shortcuts are now displayed in a human readable way
XFade:
- XFade_X1, XFade_X2 Midi command improvement
MLink:
- you can now select MLink (with shortcuts or mouse pointer) like channels (eg +/-/Thru are available)
Joystick:
- Joystick level is exported to OSC output
If you appreciate the software, please consider making donations.
Enjoy.
Nicolas BATS
:Light.It's available for each supported platforms (mac0S 10.5->10.8, windows, Linux 32b, Linux 64b).
news:
General:
DMX:
Scroller:
Shortcuts:
XFade:
MLink:
Joystick:
Enjoy.
Nicolas BATS
The following user(s) said Thank You: colinc, quico, reni, xtineb, antoine, dFVarela, loupiotes, SaFaRi187
- passa
13 years 8 months ago #5498
by passa
Replied by passa on topic 3.0.11 Release
salut, et encore et toujours, bravo eheh
bug etrange de touchosc avec iphon: lorsque j'enclenche dans dlight la fonction osc writer apres avoir spécifié l'ip de mon telephone, touchosc se ferme sitot que je tape go ou chanel, par exemple. je mets l4osc writer sur off et hop plus de bug. Suis-je le seul avec ce probleme?
13 years 8 months ago #5506
Replied by sl1200mk2 on topic 3.0.11 Release
je suis en montage demain à Londres et j'essaierai de connecter mon tel avec la 3.0.11 et du coup je pourrais te dire ce qu'il en est avec un un tel Android et Control.
- Barrillet
13 years 7 months ago #5518
by Barrillet
Replied by Barrillet on topic 3.0.11 Release
Merci pour le boulot!
Mais...
Avec cette version j'ai un souci sur le MIDI.
J'utilise ableton Live pour envoyer des sub (un plugin qui convertit le son en impulsion midi), et quand la fréquence est trop rapide Dlight "oublie" certaines info (en clair sur un effet de sirene ou les projos devraient clignoter, ben des fois il saute un clignotement)
Sur la version précédente tout fonctionne correctement par contre, et je n'ai jamais eu ce souci sur une version antérieur.
C'est grave docteur?
Mais...
- passa
13 years 7 months ago - 13 years 7 months ago #5532
by passa
petit doute:pour exclure un master de l'enregistrement de mémoires (salle, par exemple), dans mon souvenir il fallait cocher la ptite case noir/rouge sous le bouton de flash/time des masters. Alors soit ma mémoire défaille soit cela ne marche pas dans 3.11.
oups, bon, je dois constater que ma mémoire est défaillante: ce petit bouton est la touche de flash solo; quelqu'un pourra-t'il me rafraichir la mémoire pour exclure un sub de l'enregistrement?
Et de un message pour rien, désolé, je viens de retrouver la touche, celle ou il y a le numero du groupe ou du fx chargés dans les subs. A bientot pour d'autres fulgurances
Last edit: 13 years 7 months ago by passa.
- matthieu
13 years 7 months ago #5539
by matthieu
Replied by matthieu on topic 3.0.11 Release
Tu clique sur la fenetre bleue claire du sub audessus de flash pour qu'elle devienne orange
cqfd
cqfd
13 years 7 months ago #5544
@Passa,
j'ai testé la 3.0.11 et les commandes OSC avec mon tel et tout fonctionne bien (j'utilise Control pour afficher le layout)
@Padbol,
c'est grave oui et il faudrait d'autres infos pour pouvoir débugger ça.
ouvre un topic à ce sujet pour qu'on en parle.
@Padbol,
- colinc
- Thank you received: 22
13 years 7 months ago #5689
by colinc
Replied by colinc on topic 3.0.11 Release
If Virtual MIDI cable eg LoopBe selected both Input (Multiple Inputs) and Output
In/Out loop. Subs with MIDI controllers don't work because of Loop
Can select only one input to avoid...
But - suppose I *need* more than one input...?
Can't go back to 'Multiple' or loop problem again
Possible Solution (Pretty Please!!)
Check-Box Pop-Up with option to select one, some or all MIDI inputs...
- loupiotes
13 years 7 months ago #5729
by loupiotes
Replied by loupiotes on topic 3.0.11 Release
petit article chez moi
www.lesloupiotes.fr/wordpress/?p=410
:woohoo:
Time to create page: 0.222 seconds
