- Thank you received: 2
3.0.10_b1
- guillaumeL
En ce qui concerne les accents je viens de vérifier qqc. J'enregistre ma conduite sous "test accents éè" ca enregistre mais ca veut plus l'ouvrir, ca dit "operation did not occure". Je la renomme depuis l'explorateur windows en "test accents" puis je l'ouvre avec Dlight. Et là ca l'ouvre avec le bon nom "test accents éè" et non "test accents".
Vraiment étrange mais ca dérange pas beaucoup en effet.
A plus
Guillaume
- colinc
- Thank you received: 22
sl1200mk2 wrote: @Tous,
la 3.0.10_b2 est dispo.
Merci de tester les bugs rapportés par rapport à la _b1
@Colin & xtine
could you please re-test patch and Sample stuff
As Xtine, the Patch and Sample stuff seem good (Clone now works ok)
But...
From 3.0.10_b1, and now 3.0.10_b2, both with TouchOSC and Control, the transport commands have stopped working (ie GO, PAUSE, GOBACK). (3.0.9 worked ok). Other OSC stuff seems to work ok
Regards
Thanx for testing.
i think we have to figure out why this happen and i think it's related to the trick for preventing button release to send a command.
with PD, everything is working as expected, but with PD, i'm sure to send an integer after the command (eg /seq/go 1)
i think both TouchOSC and Control send string instead of int.
i'll look into that in the next couple of days and come back to you.
in the meantime can't you try to cast command sent by both TouchOSC and Control to an int to see if it makes a difference?
with the last code from your fork (with the tweak i sent you) GO command works as expected...
at least it fires GO
WTF
i've just tested 3.0.10_b2 on a windows computer and Control code, and DL receive GO command...
did you make any progress tracking what/where error can be?
- xtineb
- Thank you received: 12
Je viens de tester avec pure data les go, goback ... (avec ton patch de test nico)
tout fonctionne
win 32 et dl 3.0.10_b2
xtine
- colinc
Nope - neither GO nor GOBACK nor PAUSE works directly( I don't use PD with Control or TouchOSC)
Here is my GO button from Control:
"name": "goButton",
"type": "Button",
"bounds": [.005,.145,.655,.330],
"mode": "contact",
"min": 0,
"max": 1,
"color": "#993333",
"stroke": "#aaaaaa",
"address" : "/seq/go",
"oninit": "launch.fillDiv.style.borderWidth = '4px';",
"name": "gobuttonLabel",
"type": "Label",
"value": "GO",
"align": "center",
"backgroundColor": "rgba(0,255,0,.5)",
"size" : "36",
Regards
i do not use PD neither to route OSC message, and your js code looks fine.
as i told you, i'm using the js file from your fork for my test and command are performing well...
wouldn't you mind trying an OSC monitor ( www.frieder-weiss.de/OSC/index.html googling 'windows OSC monitor) just to see incoming message and if your computer receive GO/GOBACK/PAUSE message as well as X1 or X2 message.
thanx
- colinc
- colinc
Bingo!
Yes, the transport functions now seem to be good - GO, GOBACK and PAUSE all work (3.0.10_b3). Both Control and TouchOSC
Regards
coolYes, the transport functions now seem to be good - GO, GOBACK and PAUSE all work (3.0.10_b3). Both Control and TouchOSC
i've just updated a new one that should fix doubleGo for TouchOsc
also in the setup, on/off message
can you try it, please
- colinc
sl1200mk2 wrote:
cool
Yes, double-Go seems licked...
Bravo
