3.0.8_b1
14 years 6 months ago #4329 by sl1200mk2
Replied by sl1200mk2 on topic Re: 3.0.8_b1
@Mode
but am I understanding you correct that you just want to _add_ @mode syntax _on top of_ RPN? As opposed to having the switch in Setup to use only RPN or only @mode?
nope, @Mode will be exclusive functions.
when you choose @Mode, everything will be @moded
In which case you wouldn't need to pay too much attention what's going on on the "other" side?
the things is RPN was the original way and so i didn't design things to be able to use [AND] and [NOT]...
for now, as i said, @mode guy will be able to type
[@] xx [ENTER] [@] yy [ENTER] to patch fast
In having said that, I do understand that there are program limitations, and proportional patching is certainly not a priority...
for now, no it's not!!
i'll perform training course next month and i would like to do so with DL3.0.8, so i need it to be published
"20 @ 2 ENTER"
that I mean DIMMER 20 to be patched into channel 2?
More dimmers to a channel would than be 12+16+45@10 enter
Dimmer 12,16,45 on channel 10
we need to be agree about that.
here's a proposal
  • when you're in channel->dimmer way (apparently the french way)
    20 @ 2 Enter, will patch dimmer 2 to channel 20
    you'll be able to override that by typing
    dimmer 20 @ 2 Enter, in that case dimmer 20 will be patched to channel 2
  • when you're in dimmer->channel way
    20 @ 2 Enter, will patch dimmer 20 to channel 2
    channel 20 @ 2 Enter, in that case dimmer 2 will be patched to channel 20
  • [/li]
what i would like to keep is the switch channel->dimmer or dimmer->channel...
hope it's clear
14 years 6 months ago #4332 by sl1200mk2
@Mode
here's weekend results for patch window, i hope i'll be fine for everyone (i guess you'll understand french)
/////////////////////////PATCH Editor///////////////////////////
[CH] xx [@] yy: patch le dimmer yy sur le circuit xx
[@] yy: patch le dimmer yy sur le circuit inscrit en sélection
[CH] xx [@] yy [THRU] zz : patch les dimmer yy jusqu'à zz sur le circuit xx
[@] yy [THRU] zz : patch les dimmer yy jusqu'à zz sur le circuit inscrit en sélection
[DIMMER] xx [@] yy: patch le dimmer xx sur le circuit yy
[DIMMER] xx [THRU] zz [@] yy: patch les dimmers xx jusqu'à zz sur le circuit yy
[CH] xx [DELETE] yy : efface le dimmer yy du circuit xx
[CH] xx [DELETE] yy [THRU] zz : efface les dimmers yy jusqu'à zz du circuit xx
[DIMMER] xx [DELETE] : efface l'affectation de circuit du dimmer xx
channel->dimmer
[DELETE] yy : efface le dimmer yy de l'affectation du circuit inscrit en sélection
[DELETE] : efface tous les dimmers du circuit inscrit en sélection
[DELETE] yy [THRU] zz : efface les dimmers yy jusqu'à zz du circuit inscrit en sélection
dimmer->channel
[DELETE] yy : efface l'affectation de circuit du dimmer yy
[DELETE] : efface l'affectation de circuit du dimmer inscrit en sélection
[DELETE] yy [THRU] zz : efface l'affectation de circuit des dimmers yy jusqu'à zz
xx [@] yy will lead to the prepending of [CH]
xx [@] yy will lead to the prepending of [DIMMER]
tell what do u think about this,
Nico
14 years 6 months ago #4338 by flk
Replied by flk on topic Re: 3.0.8_b1
Great work!
I am currently away from my computer, so if you enter the patch window, what is the default - dimmer > channel? channel > dimmer? Or is that a preference that is saved with the show file (i.e. it remembers it when you re-open DL)?
Cheers,
Freddy
14 years 6 months ago #4341 by totoine
Replied by totoine on topic Re: 3.0.8_b1
Salut à tous !
Voilà quelque temps que je n'avais pas utiliser DL. Mais me revoilà dedans.
Super amélioration. Très bonne intégration du @Mode. Vivement qu'il marche partout !! :D
J'ai essayé de suivre les quelques pages de discussions sur cette nouvelle bêta. mais pas facile (surtout avec mon niveau d'anglais :D) je suis désolé, mais je me sens incapable de prendre pat à la discussion dans la langue de shakespeare...
Pour le @Mode :
- pour la fenêtre Patch, il me semble que tu as fait le tour des besoins.
- Si j'utilise step_load, il n'essaye pas de charger la step désiré, mais la Cue.
- La fonction Wait ne marche pas.
En explorant un peu comme ça, un certain nombre d'idée qui me sont passé (pour les temps futurs qui permettront de le faire...)
- Avoir la possibilité de conserver la disposition des fenêtres ouvertes quand on enregistre le show. Pourquoi ne pas avoir chaque élément qui compose la fenêtre principale complètement indépendante pour faire la disposition (et les tailles) que l'on veut.
- En MIDI, serait-il possible d'assigner un group sur un Program Change, pour ne pas être obligé de toujours passer par des Subs ?
- Toujours en MIDI, est-ce que le retour d'information marcherait facilement quand on change de MidiSwitch ?
Je continue mon petit tour.
14 years 6 months ago #4348 by sl1200mk2
@totoine,
je regarderai les bugs que tu décris pour l'@mode, mais vu que tout ça à beaucoup bougé depuis la b1, je ne serais pas surpris qu'ils aient disparus ;)
oui ça c'est une bonne idée!
je ne pense pas l'écrire pour la 3.0.8, donc il faudra que tu me la rappelles pour la suivante
non
il fonctionne déjà, mais le retour d'info Midi ne fonctionne que pour les Subs...
c'est le gros projet de la 3.0.9
14 years 5 months ago - 14 years 5 months ago #4401 by totoine
Euh je ne crois pas que ça marche vraiment ...
En changeant de MidiSwitch (et donc d'affectation des controller midi sur d'autres subs), les potards ne modifie pas. Il reste sur la valeur du MidiSwitch précédent.
Autre petit bug dans le setup MIDI.
Quand on veut affecter un controller à un channel ou submaster supérieur à 100. Si on augmente le numéro du channel ou submaster (ou autre valeur dépassant 100) par les petites flèches, la valeur retourne automatiquement à 100.
Il arrive quelque fois aussi lorsque je modifie le numéro du controller MIDI par les petites flèches que le compteur augmente (ou diminue) sans s'arrêter. Pas moyen de l'arrêter. La seule solution est de fermer la fenêtre MIDI.
Il affiche alors un message d'erreur mais j'ai oublié de le sauvegarder pour te l'envoyer. J'essaye de reproduire le bug pour faire suivre.
Je suis sur MacBook Pro OS 10.7, dernière version d'XQuartz.
a bientôt
Last edit: 14 years 5 months ago by totoine.
14 years 5 months ago #4402 by totoine
Une autre question aussi :
Quand on charge un pas de séquence par la fonction Step_Load (donc sans passer par un GO) les MLink ne se marche pas. Est-ce quelque chose de voulu ou est-il possible de le rajouter.
En attendant c'est pas très grave, on peut charger en prépa pour faire le GO, mais des fois c'est plus simple de recharger directement le pas de séquence.
a bientôt
14 years 5 months ago #4403 by sl1200mk2
c'est que j'ai du oublié de faire un update midi de l'état général de DL quand on switch...
bien vu!
ok je vais le corriger
oui, celui là, je sais pas encore le résoudre.
C'est un fonctionnement voulu, et comme tu le précises, si tu veux les MLink, tu charges en x2 et t'envois ton GO ;-)
merci pour ces retours,
14 years 5 months ago #4434 by totoine
Salut !
une petit remarque (qui date de la 3.07).
L'utilisation de la fonction pour n'afficher que les Submasters utilisé. Si tu es en page 7 et que tu actives la fonction, alors tu restes en page 7 et donc aucun submasters ne s'affiche.
Est-ce qu'il ne faudrait pas que lorsqu'on active cette fonction retourner automatiquement en page 1 pour voir la liste des subs et non pas une page vide ??
à peluche
14 years 5 months ago #4441 by sl1200mk2
@totoine
t'es sur de toi?
parce qu'ici, mon DL retourne bien à la page1 quand on est sur la page7 et qu'on clique sur la braguette magique(;-)) pour n'afficher que les subs utilisés.
si aucun sub n'est actif, c'est sûr, on se retrouve avec une zone de submaster vide...
14 years 5 months ago #4446 by totoine
Alors effectivement, je viens de mieux comprendre ce que j'ai essayé d'expliquer :
Tu as raison, quand tu cliques sur la baguette magique (ca y est, je sais comme elle s'appelle) la première fois, tu retournes bien en première page.
Mais si tu l'as déjà utilisé alors quand tu la ré-utilise à nouveau, il retourne sur la dernière page que tu avais vu en mode baguette magique.
Donc si tu as moins de subs actifs que la dernière fois, tu arrives sur une page vide puisque d'un numéro supérieur au nombre de page que tu as de subs actifs !
Peut-être faudrait-il qu'il retourne sur la première page à chaque fois pour éviter ce genre d'inquiétude ?
J'espère avoir réussi à être clair sur la fatigue de ce soir.
En tout cas, je viens de passer une semaine sur cette version allumé toute la journée avec deux lives par soir, aucun bug à à déclarer !
Bravo pour tout ce boulot !
14 years 5 months ago #4452 by sl1200mk2
ok, je vais mettre en place ce fonctionnement pour la b2, tu me diras ce que t'en penses.
14 years 5 months ago #4480 by sl1200mk2
@totoine
en y réfléchissant bien, quand tu utilises le midiswitch, je ne peux pas updater les controleurs carje n'ai pas moyen de connaitre leur état...
le midiswitch sert 'juste' à modifier les affectations des controleurs...
14 years 5 months ago #4481 by sl1200mk2
@everybody
je pense que je tiens la beta2, be ready to test ;-)
The following user(s) said Thank You: pipou
14 years 5 months ago #4488 by sl1200mk2
3.0.8_b2 is public!!
Time to create page: 0.398 seconds
