3.0.7_b11
- lafond
sl1200mk2 wrote: @callas
dans la fenetre shortcut, il y a un icone (le deuxième en haut à gauche) qui sert au redimensionnement automatique de la fenetre.
peux-tu l'essayer et me dire si il fonctionne?
No No No comme dirait la défunte Amy l'icone de redimensionnement ne fonctionne pas chez moi
mac osx 10.5.8
RIP Amy!
est-ce que sur un nouveau sho, la fenêtre des shortcuts et aussi trop grande ?
- lafond
RIP Amy!
Yes nouveau show ou pas, bouton de redimensionnement cliqué cela ne change rien pas moyen de changer la taille de la fenetre shortcuts
- samir
RIP Amy!
Same here, for 3.0.7_b11 *and* for 3.0.7 Release (Windows 32 Vista HP)
Also, The MIDI Show Control (MSC) Device ID dropdown has lost '0' as the first number (MSC Spec allows for Device ID to start from 00H to 7EH plus 7F 'All Call') (I was testing SFX6 -> DLight MSC usage, and originally had Device ID '0' , but after installing 307b11 and 3.0.7 R, I had to reconfigure all the cues in SFX6 from '0' to '1'
Best wishes
does the shortcut window is also too much bigger, or does the 'refactor size' button does not work?
about MSC, sorry for the inconvenience but it appears that on my Mac, id 0 had very wrong behaviour...
so i decided to remove 0.
all the best,
- samir
sl1200mk2 wrote: @Colin
Does not work - if I click it, the window 'bounces' down to a slightly smaller size, then *immediately* bounces back to its original size. And if I try to use it after maximizing it with thw Windows Maximize button, it doesn't work, and licking 'Restore' on the Windows button throws it partly of screen, and you hahave to drag it and resize it manually
sl1200mk2 wrote: about MSC, sorry for the inconvenience but it appears that on my Mac, id 0 had very wrong behaviour...
all the best,
No bother - the Device ID 1 lower limit seems ok
Regards,
let's hack:
in the file DLight.tcl, find this text 'shorttble'
close to it you'll see something like '-height 80'
change the 80 to 20, save and relaunch DL.
can you please make tests to see what height is the maximum for you.
- samir
Changed the value to 20, no change - the window opens the same height as before ie the full height of the desktop
Best,
- samir
On a new show, it opens about mid-way between top and bottom of screen, and is about 2/3rds of the size (height) of the screen. But the resize icon still only does the 'bounce' thing I described before, ie does not increase or decrease the height of the window.
Best wishes,
ok,
can you tell me what is a relatively good size (25, 30, 34...)
- samir
25 is about right
best,
