1.29-b5
17 years 2 months ago #250
1.29-b5 was created by sl1200mk2
1.29-b5 version of
:Light is available for every supported systems.
This is a very beta version, and please MAKE A COPY OF YOUR SHOW BEFORE USING THEM
Submasters:
This version introduce "Book" concept for submasters. Each Book contain 250 Submasters, and you can switch between 20 Books as long as you have register them in the setup.
(This is a big update !!!)
Midi:
a recycle symbol is now present near the Midi Input description. when you move a midi controller via the nanoK for example, it show "Channel 1, Controller 23, Value 100". Click the recycle button to automatically fill values
General:
big update (also) concerning internal timers. I've noticed in previous version that a XFade and a MLink with the same time didn't reach their target synchronously. 29-b5 should correct this.
:Light is available for every supported systems.This is a very beta version, and please MAKE A COPY OF YOUR SHOW BEFORE USING THEM
Submasters:
Midi:
General:
17 years 2 months ago #251
Replied by sl1200mk2 on topic Re:1.29-b5
une petite erreur s'est insidieusement glissée dans cette béta qui empêche la commande MIDI d'un submaster timé.
fixed for -b6
fixed for -b6
- nathalie
17 years 1 month ago #290
by nathalie
Replied by nathalie on topic Re:1.29-b5
Nous avons installé la version 1.29 b5 Quartz sur un MacBook 10.5.2 = message d'erreur "l'application a quitté inopinément", le rapport d'erreur disait : incompatibilité libfontconfig.1.dylib version 3.0.0.
Nous avons ensuite installé la version 1.29 b5 Dlight X5_X11 et celle-là semble marcher, du moins à l'ouverture. Pouvez-vous nous expliquer pourquoi ? Et quel est le problème avec X11 ? signé : novices X11 !!! Merci d'avance.
17 years 1 month ago #295
si vous pouvez faire un update de votre os en 10.5.8, je ne saurais que trop vous conseiller d'installer XQuartz 2.4.0 et d'utiliser les versions XQuartz de
:Light.
XQuartz est un serveur graphique (comme X11) mis à jour régulièrement (au contraire d'X11)
tenez moi au courant de vos essais et installations.
:Light.XQuartz est un serveur graphique (comme X11) mis à jour régulièrement (au contraire d'X11)
Time to create page: 0.160 seconds
