problem with cue order in sequence
- homesepia
It's with dlight 2.2 macosX version
If I start recording cues from step 1, order in secuence is ok, but when I add new cues then the first cue I record is putted not on new step but one before the last one.
like this:
I have recorded 2 cues, so have this secuence:
s0 q0
s1 q1
s2 q2
now I'm working in scene mode on step2, make some changes and type '3q', so cue 3 is recorded.
But then the secuence looks like this:
s0 q0
s1 q1
s2 q3
s3 q2
and now the console is on step2, scene mode.
If now I continue recording (4, 5, ..) the new cues always put after last cue number, but it doesn't match anymore with step number, because q2 always moves to new step:
s0 q0
s1 q1
s2 q3
s3 q4
s4 q5
s5 q2
If I work on preset mode it hapens the same.
If I go to secuence window to arrange it, have to change also times and names, and when I come back to continue recording cues It happens the same, the first recorded is putted before the last.
so some help svp... www.nicole-banana.com/components/com_kun.../emoticons/blink.png
and a small bug: dlight closes when making a crossfade (with nanok faders) if there's not a next step.
anyway santé pour dlight!
first, i can't reproduce the behaviour you describe.....
s0 q0
s1 q1
s2 q3
s3 q2
"R" is the default shortcut to record cues, did you change this to "q" ?
because "q" is the existing shortcut for "cue" (is this shortcut usefull????)
maybe something is wrong when you modify shortcuts.....
do you observe the same behaviour with a fresh show without modifying the shortcuts?
saludos
- homesepia
I type '3r' ( I changed shortcut 'R' to 'r').
Now I try it with with a fresh show without modifying the shortcuts, with a brand new re-installed dlight.
I record cues 1 and 2:
s1 q1
s2 q2
I save the show and quit dlight. Then re-open dlight, open the last show, and when recording cue 3, oh-oh, happens the same:
s1 q1
s2 q3
s3 q2
Then I record cues 4 and 5:
s1 q1
s2 q3
s3 q4
s4 q5
s5 q2
salut
i downloaded the 2.2 from the web site
i start DL (wich start after fucking long delay - will have to fix this)
i do:
*create new show
*"R" -> create cue 1, sequence is like
s0 q0
s1 q1
*"R" -> create cue 2
s0 q0
s1 q1
s2 q2
*"3R" ->create cue 3
s0 q0
s1 q1
s2 q2
s3 q3
don't you see this behaviour ?????????
- homesepia
quit DL
open DL
load the show
type "4R" and cue 4 is loaded after cue 3.....
so we have a problem if the behaviour is different on mine and your computer...
can you try to remove the DL executable you have before installing a new one and try again?
does anybody else see a wrong behaviour when recording cues?
- homesepia
- homesepia
That happens when there are no more empty steps in secuence.
For creating a new show, I use to open an old one and erase all FXs, groups and steps. By this way I keep shortcuts and background color, and each new cue I record DL loads on a new step. But then when re-opening the show and adding new cues, it keeps always the last step on last position and adds the new ones before that.
I see that when making a new show, there are 20 empty steps at the begining and DL automaticaly adds an empty one each time a new cue is recorded. In this case, there's no problem with cue order.
You can try it recording for example two cues in a new show, deleting then steps 3-20, saving it, closing and re-opening it and then trying to add new cues.
Hope it helps...
salut
- bdt
Yes I have the same problem.
When I record a new Cue, it is automatically inserted at a wrong step in the sequence.
I have to remove this step, go to the right place, and then insert a new step and affect the new Cue.
Salut
J'ai le même probleme.
Quand je crée un nouveau Cue à un endroit donné dans ma conduite, DL l'insère automatiquement ailleurs (hier c'était sur mon Step 12 systématiquent).
Il fallait que je remonte à cet endroit (Step 12) pour l'effacer, puis revenir là où j'en étais, inserer mon step et y affecter mon Cue.
Macbook C2d, OSX 10.5.8, DL2.2, Enttec USBDMX PRO.
- bdt
En attendant j'avais désactivé dans le setup l'option "Auto load CUE in sequence".
- bdt
J'incrimine ma conduite car j'avais un autre bug : l'export ASCII qui plantait et en examinant les fichiers j'ai trouvé un FX en cause. Après suppresssion de cet FX, l'export fonctionne à nouveau.
Il faut dire qu'en tâtonnant lors de ma première conduite, j'avais occasionné des plantages.
En revanche, en testant j'ai trouvé deux petites choses, je les poste dans le bon topic (2.3)
