ArtNet problems
- NachoL
Thanx a Lot, I have a gig in Germany and I need 4 Universes but I can not Afford to buy a new node, I really would appreciate if I can make this ones work
in Artnet, the network card of your computer needs to be in the same IP area of the nodes.
generally node are set as 2.0.0.1, 2.0.0.2 etc... with a netmask like 255.0.0.0
so you need to configure your card as 2.0.0.100 (another IP) and a netmask like 255.0.0.0
once it's done in the setup/artnet, in the output part you select the network card of your computer and click on 'who's online'.
each present node should respond.
- NachoL
of you know for sure that the IP is 2.0.0.101, just write it in the manual registration and click on 'add'
- NachoL
- NachoL
I also tried the Showtec NET-8/5 with the same results
- NachoL
Your last picture is OK, click then on available and you should be able to use it.
if you are on macOS sequoia make sure that the Privacy > Local Network toggle is on for DLight
if it's on toggle it off and on again
- NachoL
- NachoL
- NachoL
tell me if it's ok (an please post a picture of your hand made node)
