Impossible de SAVE ma conduite / Plantage systématique !!!
- matyeuyeu
1 year 10 months ago #27598
by matyeuyeu
Impossible de SAVE ma conduite / Plantage systématique !!! was created by matyeuyeu
Salut Nico, je suis en galère. Je viens de faire des mofis sur une conduite avec des ROBE et des OXO.
Je ne peux même pas enregistrer ma conduite. DL plante direct.
JE suis sous SONOMA 14.3.1 et DL 4.4.17.
Voici le rapport de plantage, enfin que le début :
Merci pour ton aide.
Translated Report (Full Report Below)
Process: DLight [2755]
Path: /Applications/DLight.app/Contents/MacOS/DLight
Identifier: com.LightingStudioDevice.DLight
Version: 4.4.17
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-11-13 09:11:58.6989 +0100
OS Version: macOS 14.3.1 (23D60)
Report Version: 12
Anonymous UUID: E5903649-747E-77E5-874D-08B8B7056CC5
Sleep/Wake UUID: 50DE957F-4030-4107-AB1E-3173713594E4
Time Awake Since Boot: 63000 seconds
Time Since Wake: 2535 seconds
System Integrity Protection: enabled
Crashed Thread: 16 thpool-3
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [2755]
VM Region Info: 0 is not in any region. Bytes before following region: 4368744448
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 10465c000-104a00000 [ 3728K] r-x/r-x SM=COW .../MacOS/DLight
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_malloc.dylib 0x18936c3cc szone_malloc_should_clear + 352
1 CoreFoundation 0x1895b9dd8 _CFRuntimeCreateInstance + 852
2 HIServices 0x18f9a0878 CreateEmptyShape(bool, bool) + 72
3 HIServices 0x18f9a0920 HIShapeCreateWithRect + 28
4 Tk 0x10532d4c8 Tk_ClipDrawableToRect + 112
5 Tk 0x1052a3be8 0x10524c000 + 359400
6 Tcl 0x10519c098 TclServiceIdle + 72
7 Tcl 0x105178bb0 Tcl_DoOneEvent + 128
8 Tk 0x1053416c4 0x10524c000 + 1005252
9 Tk 0x105341490 0x10524c000 + 1004688
10 AppKit 0x18cf29910 _NSViewDrawRect + 124
11 AppKit 0x18d8b167c -[NSView _recursive:displayRectIgnoringOpacity:inContext:stopAtLayerBackedViews:] + 1088
12 AppKit 0x18cf29314 -[NSView(NSLayerKitGlue) _drawViewBackingLayer:inContext:drawingHandler:] + 556
13 QuartzCore 0x191729860 CABackingStoreUpdate_ + 272
14 QuartzCore 0x191781004 invocation function for block in CA::Layer::display_() + 64
15 QuartzCore 0x1917289c0 -[CALayer _display] + 1640
16 QuartzCore 0x191727b3c CA::Layer::display_if_needed(CA::Transaction*) + 736
17 QuartzCore 0x1918acda4 CA::Context::commit_transaction(CA::Transaction*, double, double*) + 512
18 QuartzCore 0x19170a8f0 CA::Transaction::commit() + 648
19 AppKit 0x18cf38b18 __62+[CATransaction(NSCATransaction) NS_setFlushesWithDisplayLink]_block_invoke + 272
20 AppKit 0x18d8eef04 ___NSRunLoopObserverCreateWithHandler_block_invoke + 64
21 CoreFoundation 0x189632d80 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 36
22 CoreFoundation 0x189632c6c __CFRunLoopDoObservers + 532
23 CoreFoundation 0x18963229c __CFRunLoopRun + 776
24 CoreFoundation 0x18963193c CFRunLoopRunSpecific + 608
25 HIToolbox 0x193bfa448 RunCurrentEventLoopInMode + 292
26 HIToolbox 0x193bfa0d8 ReceiveNextEventCommon + 220
27 HIToolbox 0x193bf9fdc _BlockUntilNextEventMatchingListInModeWithFilter + 76
28 AppKit 0x18ce10ed0 _DPSNextEvent + 660
29 AppKit 0x18d5fbeec -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 716
30 Tk 0x10533bf58 0x10524c000 + 982872
31 Tcl 0x105178c9c Tcl_DoOneEvent + 364
32 Tk 0x105267468 Tk_MainLoop + 48
33 Tk 0x105276850 Tk_MainEx + 1464
34 DLight 0x104846b60 main + 276
35 dyld 0x1891d50e0 start + 2360
Thread 1:
0 libsystem_pthread.dylib 0x189550e28 start_wqthread + 0
Thread 2:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x189515874 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x189527cf0 mach_msg2_internal + 80
2 libsystem_kernel.dylib 0x18951e4b0 mach_msg_overwrite + 476
3 libsystem_kernel.dylib 0x189515bf8 mach_msg + 24
4 CoreFoundation 0x189633b84 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x18963244c __CFRunLoopRun + 1208
6 CoreFoundation 0x18963193c CFRunLoopRunSpecific + 608
7 AppKit 0x18cf3a160 _NSEventThread + 144
8 libsystem_pthread.dylib 0x189556034 _pthread_start + 136
9 libsystem_pthread.dylib 0x189550e3c thread_start + 8
Thread 3:
0 libsystem_kernel.dylib 0x1895209d4 __select + 8
1 Tcl 0x1051df430 0x105090000 + 1373232
2 libsystem_pthread.dylib 0x189556034 _pthread_start + 136
3 libsystem_pthread.dylib 0x189550e3c thread_start + 8
Thread 4:
0 libsystem_kernel.dylib 0x18951906c __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x1895565fc _pthread_cond_wait + 1228
2 DLight 0x104695400 Thread_AutoSeqRecorder + 160
3 DLight 0x104901a54 ThreadFunc + 24
4 libsystem_pthread.dylib 0x189556034 _pthread_start + 136
5 libsystem_pthread.dylib 0x189550e3c thread_start + 8
Thread 5:
2 DLight 0x104756a24 Thread_DMXSend + 84
Thread 6:
2 libTurboActivate.dylib 0x105a73d20 0x105a64000 + 64800
3 libTurboActivate.dylib 0x105a732bc 0x105a64000 + 62140
4 libTurboActivate.dylib 0x105a730f8 0x105a64000 + 61688
5 libTurboActivate.dylib 0x105a71c2c 0x105a64000 + 56364
6 libTurboActivate.dylib 0x105adf1d8 0x105a64000 + 504280
7 libsystem_pthread.dylib 0x189556034 _pthread_start + 136
8 libsystem_pthread.dylib 0x189550e3c thread_start + 8
Thread 7:
4 CoreMIDI 0x1a314548c XServerMachPort::ReceiveMessage(int&, void*, int&) + 104
5 CoreMIDI 0x1a315666c MIDIProcess::MIDIInPortThread::Run() + 156
6 CoreMIDI 0x1a3153a64 CADeprecated::XThread::RunHelper(void*) + 48
7 CoreMIDI 0x1a31556c0 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 92
Thread 8:: caulk.messenger.shared:17
0 libsystem_kernel.dylib 0x1895157f0 semaphore_wait_trap + 8
1 caulk 0x1938f6690 caulk::semaphore::timed_wait(double) + 212
2 caulk 0x1938f6544 caulk::concurrent::details::worker_thread::run() + 36
3 caulk 0x1938f6244 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*>>>(void*) + 96
Thread 9:: caulk.messenger.shared:high
Thread 10:
0 libsystem_kernel.dylib 0x18951b9c0 kevent + 8
1 libuv.1.0.0.dylib 0x10571e9b8 uv__io_poll + 744
2 libuv.1.0.0.dylib 0x10570e4f0 uv_run + 412
3 DLight 0x104928260 reader_start + 504
Thread 11:: thpool-0
2 DLight 0x104667b80 thread_do + 288
3 libsystem_pthread.dylib 0x189556034 _pthread_start + 136
4 libsystem_pthread.dylib 0x189550e3c thread_start + 8
Thread 12:: thpool-1
Thread 13:: thpool-0
Version: 4.4.17
User ID: 501
Report Version: 12
Thread 1:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 10:
1 year 10 months ago #27599
Replied by sl1200mk2 on topic Impossible de SAVE ma conduite / Plantage systématique !!!
plusieurs symptomes possibles et plusieurs solutions...
mais celle à laquelle je pense (bien qu'il me faudrait le crash complet) c'est un caractère exotique ou mal encodé dans le nom du fichier d'une perso...
Ensuite un macOS qui mériterait d'être à jour et enfin un DL qui ne demande qu'à passer en version 4.5.
donc sur macOS, ouvre une fenêtre de Finder, affiche la racine de ton compte (la maison), appuis sur Shift+Cmd+. en même temps, ça va afficher les dossiers cachés.
tu vas trouver un dossier .DLightWorkingSho
fais en un zip et poste le ici (ou sur le Discord)
- matyeuyeu
1 year 10 months ago #27604
by matyeuyeu
Replied by matyeuyeu on topic Impossible de SAVE ma conduite / Plantage systématique !!!
Merci pour ta réponse.
Même plantage avec DL 4.5. Je suis en train de faire la maj du MAC.
Voici le fichier DLightrecovery.sho et le rapport de plantage.
1 year 10 months ago #27605
dis moi ce qu'il en est à la suite de la MAJ du macOS
- matyeuyeu
1 year 10 months ago #27612
by matyeuyeu
la MAJ est faite et ça plante toujours.
1 year 10 months ago #27613
peux-tu venir sur le Discord stp?
- matyeuyeu
1 year 10 months ago #27614
by matyeuyeu
Sorry, je maitrise pas Discord. Je viens de le mettre sur mon tel. J’essaie de te retrouver...
1 year 10 months ago #27615
ya un lien sur la page d'accueil du site
1 year 10 months ago #27617
fixed avec DL 4508
Time to create page: 0.227 seconds
