Selected directory is not writable
3 years 2 weeks ago #25614 by polillin
Selected directory is not writable was created by polillin
That's the message I get everytime I try to save. Help!
3 years 2 weeks ago #25615 by sl1200mk2
Replied by sl1200mk2 on topic Selected directory is not writable
Hi,
is it a macOS or a PC?
also which version of DLight do you use?
3 years 2 weeks ago #25616 by polillin
Replied by polillin on topic Selected directory is not writable
Windows10, 64 bits.
I use the last D::light 4.3.23, but it happened the same with the previous one
3 years 2 weeks ago #25617 by sl1200mk2
it generally means that you 've attempted to savec a sho while Windows was waiting for a reboot after an upgrade.
so you need to clean stuff a little bit...
-Close your DLight
-Open a file explorer
-navigate to C:
-in the upper side of the explorer, Select View > Show > Hidden items.
(you should see ProgramData folder)
-navigate to ProgramData/DLight folder
-send to trash everything that end or start with 'tmp'
-restart your DLight and try a save as.
tell me how it goes.
3 years 2 weeks ago #25620 by polillin
There's nothing that ends or starts with tmp. I've searched even inside all subfolders. Any other suggestion?
3 years 2 weeks ago #25621 by polillin
By the way, i,ve found I have 2 recovery files. I've tried opening them and 'save as', but I get the same directory not writable message.
3 years 2 weeks ago #25622 by sl1200mk2
Can you post a picture of your ProgramData/DLight folder?
3 years 2 weeks ago - 3 years 2 weeks ago #25623 by polillin
Last edit: 3 years 2 weeks ago by polillin.
3 years 2 weeks ago #25624 by sl1200mk2
OK... and did you try to restart your computer?
3 years 2 weeks ago #25625 by polillin
Yes, I have. Several times. Also run CCleaner several times to eliminate any tmp file and clean registers. The same result.
One observation: I have a different folder to keep my .sho files. And if I rightclick on it, it says it is a only read folder, don't know if it has anything to do with it...
3 years 2 weeks ago #25626 by sl1200mk2
And did you tried to saveAs them in other place?
3 years 2 weeks ago #25627 by polillin
Good clue! It lets me save in desk and in downloads folders, not in documents (Isuspect it is because of that 'only read' configuration, I don`t know why it has changed...) I keep trying, i'll inform as soon as I get any news...
Time to create page: 0.169 seconds
