Import/Export CUES, SUBMASTERS?
- polillin
4 years 2 weeks ago #23814
by polillin
Import/Export CUES, SUBMASTERS? was created by polillin
Hello. I have one sho. file with only submasters to work with (no cues, no steps...), and the same show, in a different .sho file with steps, cues, times--- but no submasters.
I need desperately a solution to import submasters into the sho. file with cues or viceversa, cues and steps and times... into the submasters sho. file.
I hope I could explain it right...
4 years 2 weeks ago #23815
Replied by sl1200mk2 on topic Import/Export CUES, SUBMASTERS?
Hi,
there's nothing yet in DL in order to do that.
the problem with submasters is that they can contain any object... thus DL needs to know how to import Cue first (and Sample and Palette, etc...).
I have one question for you, do you have any same cue/group numbers in both of your sho?
in that case, in your opinion how DL should behave?
exemple: you submaster's sho contains cue 1, the other sho contains cue 1. Which one should be kept?
The following user(s) said Thank You: polillin
- polillin
3 years 11 months ago #23936
by polillin
Replied by polillin on topic Import/Export CUES, SUBMASTERS?
Hola. Perdón por el retraso, no me he olvidado. En mi caso concreto, en los submasters simplemente grabo grupos para trabajar con ellos creando / editando en directo determinados cues que pueden variar según las condiciones del lugar. Entonces, yo tenía un .sho vacio con solamente submasters / substicks para trabajar lo que fuera necesario y otro .sho con las sequence estandar de gira, que hay que ir variando. No sé si me explico bien.
No sé cómo debería comportarse d:light, supongo que habrá algún modo de importar esos grupos al banco de submasters del otro .sho.
Un saludo y gracias por responder!
3 years 11 months ago #23937
Hola,
I'm not sure to understand well... but for now you cannot import only specific part of another .sho
It'll come but for now you cannot.
Time to create page: 0.269 seconds
