DYNAMIC BOTTOM
5 years 5 days ago #22119 by polillin
DYNAMIC BOTTOM was created by polillin
Is there a BUTTON hidden somewhere in the screen for this function or is it just the name of the interchangeable Devices / Submasters option?
So, I can only set it through Menu / Devices / Dynamic Bottom or through the shortcut (not very short) Shift + Control + d ?
5 years 5 days ago #22120 by polillin
Replied by polillin on topic DYNAMIC BOTTOM
It would be really useful to have a MIDI button assigned for this option, although I suspect there is no such MIDI option...
5 years 5 days ago #22121 by sl1200mk2
Replied by sl1200mk2 on topic DYNAMIC BOTTOM
HI,
you can automate dynamicBottom toggling in the setup if you select 'dynamic selection for Channel' option.
Thus each time you select a device it will switch state. (use ESC to revert to submaster)
There is also Shift+Tab unknown shortcut to toggle dynamicBottom State
The following user(s) said Thank You: polillin
Time to create page: 0.187 seconds
