Automatically change cue programming for selected channels
- mjodar
5 years 4 months ago #21656
by mjodar
marc
Automatically change cue programming for selected channels was created by mjodar
Hi all!
I have a show where I have about 30 dimmer channels programmed (channels 1-30). Now I want to add a new fixture on channel 4. Is there a way to shift on every cue, channels 4-30 and put them on 5-31? Or I have to reprogram manually all the 100 cues?
Hope it makes sense.
Thanks very much!!
Thanks very much!!
marc
5 years 4 months ago #21657
Replied by sl1200mk2 on topic Automatically change cue programming for selected channels
hi,
with a recent release of
:Light yes
open the Patch, in the left part select your channels from 4 to 30, type 5 in the commandLine and choose the MOVE/move selected channels to another channel option (on the upper right part of the Patch window).
this should move all your channels in every cue/group/chaser/palette, etc.. and do want you want.
tell me if it's ok.
:Light yes open the Patch, in the left part select your channels from 4 to 30, type 5 in the commandLine and choose the MOVE/move selected channels to another channel option (on the upper right part of the Patch window).
tell me if it's ok.
The following user(s) said Thank You: mjodar
- mjodar
5 years 4 months ago #21659
by mjodar
marc
Replied by mjodar on topic Automatically change cue programming for selected channels
Yes! That was exactly it! I was not on the latest version, that's why i couldn't see the option.
Thanks Nicolas, and keep up the good work!
marc
5 years 4 months ago #21660
thanks,
glad it works because it's one of the monstruous function (it involves a lot of things internally) of the soft.
Time to create page: 0.136 seconds
