Fixture Definition Vari-Lite VL1100TS 16bit (27ch)
6 years 7 months ago - 6 years 7 months ago #19784 by SaFaRi187
Hi all,
For a new show we are experimenting with a moving head who was available at our venue.
Can anyone help me with a fixture definition file for that specific spot?
I've tried already importing the VL1000 file from the download section on the site, but no luck.
Some weird movements and flickering, I assume that one or more parameters are off...
Also, I've didn't had any luck yet in creating it by myself in the editor of D::Light.
I've joined the DMX-chart in this post in the hope that someone has better luck than me! ;-)
I also joined my best shot in creating a definition for the spot.
Any help would be appreciated,
Kind regards,
Bram
Last edit: 6 years 7 months ago by SaFaRi187.
6 years 7 months ago #19785 by sl1200mk2
Hi,
can you make a .zip of your .dld?
6 years 7 months ago #19786 by SaFaRi187
There you go. Thanks already for your help!
6 years 7 months ago #19787 by sl1200mk2
so,
it's not easy to work with non RGB nor CMY fixture....
Blue/Amber/Magenta are not common parameters... maybe you should set Cyan/Yellow/Magenta for offset 9, 10 and 11
offset 12 is Gobo (not colorWheel), 13 is rotation and 14 is FINE of 13
except that, your personality should work.
what does not work from your tests?
The following user(s) said Thank You: SaFaRi187
6 years 7 months ago #19789 by SaFaRi187
Again, you saved my day!
Everything works as it should be now.
Thanks again Nicolas!
Bon weekend.
Bram
Time to create page: 0.367 seconds
