short pulse on flash button?
6 years 10 months ago #19204 by birt
short pulse on flash button? was created by birt
i have to program a show where they have a door that opens and closes with DMX. what i need to make is a button that gives a pulse of a certain length on a channel. to open and close are 2 different lengths so ideally i have a button for each. i just don't know how to program a flash button to hold for a set timing on each push. (channel is already on non-dim)
6 years 10 months ago #19205 by sl1200mk2
Replied by sl1200mk2 on topic short pulse on flash button?
Hi Birt,
You can use a TIME submaster. Inside the submaster editor, fill the hold value for as long you want to trigger the next value and set 0 to times.
Like that, you hit the time button of the flash, it goes up, stays up during the hold time and get down.
Will that be fine?
The following user(s) said Thank You: birt
Time to create page: 0.174 seconds
