- Thank you received: 3
All scenes are played after each other BUGG??
- SoundSurfer
7 years 5 months ago #18366
by SoundSurfer
All scenes are played after each other BUGG?? was created by SoundSurfer
Hey Nico,
First of all, i appreciate all the work you are doing for all of us!
I have a show on friday, that i havent done in about a year. The file was made with an earlier version of dlight. I dont know why, but when you "go" the first cue, with spacebar, or with an MSC GO via qlab, all the scenes will play after each other, as if the fade out time is like a follow.
the files is attached. hope you can help...
Jannes
Jannes
7 years 5 months ago #18367
Replied by sl1200mk2 on topic All scenes are played after each other BUGG??
Hi,
it's not a bug...
at some point, I've reduced minimum timing to 0second (instead of 0.1s) but ancient sho are recorded with 0second for the WAIT time, and thus, they're now displayed with 0second which is equal to autogo for each step...
the solution is:
open the Sequence window
each time you don't want autogo, select the step, be sure command line is empty and press 'w' (Wait shortcut)
hope it's clear.
it's not a bug...
the solution is:
hope it's clear.
The following user(s) said Thank You: Emanresu
- SoundSurfer
7 years 5 months ago #18368
by SoundSurfer
Replied by SoundSurfer on topic All scenes are played after each other BUGG??
Ok, i think i found the problem. The newer version of dlight works with a dot (.) instead of a 0 for the values in the sequences. so old version had a 0, therefor all the cues were following in 0.
cheers!
Jannes
cheers!
Jannes
- SoundSurfer
7 years 5 months ago #18369
by SoundSurfer
i just figured it out. but still thanks anyway. its easier to double click in on the 0's in the sequence window, they will turn into dots. Thats is way quicker.
ps looking forward to name channels in the patch window!!
cya soon!
cya soon!
Time to create page: 0.213 seconds
