devices
- lewisinheaven
www.chauvetprofessional.com/wp-content/u...o_DMX_EN_Rev1_WO.pdf
Actually I want to control them old-school with static color and zoom. Nothing fancy, only the dimmer level changes in my cues. What is the most simple way to do this? Where can I find more info on creating a device and creating palettes. The Wiki is in french and not so comprehensive to me.
Specific questions I have regarding making a 9ch personality for the COLRado 1 solo in SSP mode:
1.how do I enter the Zoom parameter that the COLORade needs in the device personality editor?
2 what does the home column mean?
thanks in advance Ruben
the whole process for using devices in DL is:
-create or write personality (Personality Editor)
-load personality in your .sho (Device Listing)
-set a 'channel' for the device (Device Listing)
-patch it (Patch)
-record Palette of colours or focus or whatever (Device Commands)
after that in the main window, you set a palette to a device, you give an intensity to the device and you hit Record (R shortcut).
DL will record a DeviceLink which contains palette reference.
this is the device mode, it's not very complicated.
so, following the DMX chart of your device, you first need to choose which mode you wanna use.Actually I want to control them old-school with static color and zoom. Nothing fancy, only the dimmer level changes in my cues. What is the most simple way to do this?
following your needs, I would say the SSP mode.
in TOUR mode, you'll need to patch 9 channels (once again, this is the ooooold fashion style).
In that case, ch1 will control the dimmer, ch2 = Red, etc...
if you work like that, you'll want to record cue as each parameters of your device is a dimmer
you can use google translate or another service to translate itWhere can I find more info on creating a device and creating palettes. The Wiki is in french and not so comprehensive to me.
you add an offset, you set attribute to BEAM and set the PARAMETER to zoom1.how do I enter the Zoom parameter that the COLORade needs in the device personality editor?
HOME is like a reset.2 what does the home column mean?
when you start creating a Palette, it's a good thing to set your device first at HOME, like that there's no colours (if HOME is 0 for colours) shutter is open (according to the dmx chart, if HOME is set to HOME position, etc...).
- lewisinheaven
it's kind of working in SSP mode now.
only thing is that record is not always working. I have too practice a bit I guess. For some channels, after record nothing happens. And I managed to record 8 channels so I have to find out what I'm doing wrong here.
