triggered stopwatch
11 years 8 months ago #9296 by birt
triggered stopwatch was created by birt
i need to start and reset a stopwatch during a performance and i want to do this with dlight
is there a way to do this with the built-in stopwatch? (it is very small though) or can this be triggered/reset with a shortcut that i can press at the same time as the cue that needs to start it?
i tried to find a stopwatch that can be triggered with OSC or MIDI but i haven't been succesful yet.
any ideas?
11 years 8 months ago #9303 by sl1200mk2
Replied by sl1200mk2 on topic triggered stopwatch
did you give a shot to Midi TimeCode?
11 years 8 months ago #9304 by birt
Replied by birt on topic triggered stopwatch
no i didn't really understand how that works. it looked to me like a way to trigger cues on certain times. i don't need to do that. i need to have a stopwatch for the dancers that gets reset at certain cues.
11 years 8 months ago #9329 by fIfOU
Replied by fIfOU on topic triggered stopwatch
Hello Birt,
Did you solve your problem ?
Are you on mac or PC ?
11 years 8 months ago #9373 by birt
i am on mac.
i used a simple app called "pace clock"
when the clock needed to be reset i pressed go on my Nanokontrol and R on the keyboard (to reset that clock) at the same time. it's not connected but it did the job.
i tried to put the clock on an external screen but it seems Dlight doesn't like external screens. the main window was still open but i couldn't see it on any of the screens until i disconnected the external again.
11 years 8 months ago - 11 years 8 months ago #9377 by fIfOU
Hi Birt,
I have a little patch that should suits you.
A timer triggered in OSC by D::Light. You can Run, Pause, Reset timer with Subs n°21, 22, 23.
You can even add these triggers in your cue list with MLinks.
It runs under Isadora. (video software not really made for that, but it works well)
Download Isadora v1.3.1f06 (fully endless functionnal demo - No save) here :
troikatronix.com/download/isadora-download/
and open attached patch.
In D::Light setup, add an OSC writer :
IP Address : Localhost
Port : 1234
Activate OSC by clicking the OFF red led to green.
and you're done.
Hope it helps.
Don't forget to donate to D::Light if your show goes on tour..
Best
Philippe
Last edit: 11 years 8 months ago by fIfOU.
11 years 3 weeks ago #10665 by dylan
Replied by dylan on topic Chronometre-timer.
est il possible de mettre un chronomètre ou timer sur dlight qui démarrerai à un certain go. Histoire d'avoir une timeline de mon show.
J'aimerais un chrono sur un deuxième écran.
est ce possible?
D'avance merci
11 years 3 weeks ago #10681 by fIfOU
Replied by fIfOU on topic Chronometre-timer.
Hello
Tu est sous Mac ou pc ?
11 years 3 weeks ago #10683 by dylan
Sous PC… Linux
11 years 3 weeks ago #10684 by fIfOU
Dommage, j'avais un truc sous mac..
11 years 3 weeks ago #10685 by dylan
Ca m'intéresse :-)
11 years 3 weeks ago - 11 years 3 weeks ago #10686 by aroom
Replied by aroom on topic Chronometre-timer.
par ici les brocolis : getdlight.com/index.php/en/forum/1-gener...gered-stopwatch#9377
merci à l'onglet recherche ;)
au passage, j'ai fusionné les 2 articles
Last edit: 11 years 3 weeks ago by aroom.
11 years 3 weeks ago #10688 by fIfOU
Ah oui,
Merci aroom,
j'avais oublié que j'avais déjà balancé le patch du timer OSC sur le forum !
Philippe
11 years 3 weeks ago #10689 by aroom
par contre, la pièce jointe a disparu. est-ce que tu pourrais la reposter stp ?
11 years 3 weeks ago #10690 by fIfOU
Hop !
The following user(s) said Thank You: aroom
