- Thank you received: 1
scene master behaving strange
- birt
11 years 8 months ago #9177
by birt
scene master behaving strange was created by birt
in some shows i have the scene master set to 90. i then use it to set adapt the brightness to the different theatres on tour. (and so i can go a bit brighter when there is a fixed grid higher up than the theatre the show was made in)
the problem i have is that this master sometimes goes back to FF during a show. mostly after blackouts.
it also happens instantly when updating a certain cue and that is very annoying when i update it during the show as the audience sees the intensity jump up.
11 years 8 months ago #9185
Replied by sl1200mk2 on topic scene master behaving strange
Hi,
sorry for not responding to you earlier...
and sorry again because I've released a new beta without a fix for this issue witch can be very annoying...
in the meantime you can use Grand Master curve if you want to adapt all channels levels...
11 years 8 months ago #9190
also can you please check if this also happen with the latest beta...
thanx,
thanx,
- birt
11 years 8 months ago #9226
by birt
Replied by birt on topic scene master behaving strange
the grand master also affects the subs so a small light on stage and the house lights would go with it.
i will check if it behaves like this in the beta
- birt
11 years 8 months ago #9287
by birt
in the beta 4.0.20 this still happens. the scene master jumps to FF when updating a cue.
11 years 8 months ago #9288
hey Birt,
can you please upload your sho and tell me some details about how to reproduce the bug?
thanx
thanx
Time to create page: 0.729 seconds
