Shortcuts ??
11 years 10 months ago #8953 by vbs
Shortcuts ?? was created by vbs
I am have a deleting que's and steps problem with Dlight3.24
If i delete que 4 tru 6 it ask do you want delete que 6???
If i delete step 7 it ask do you want delete que 6???
It shoo on the screenshots i uploaded
Also i like to work with al the commands on a separate program keyboard
If you delete you have to confirm yes or no …….Is there a short cut for or can it be made like enter enter ???
The go to step is in 0 sec while the fade time in the sequins is set on 5 sec.
can this also be altered in time, like go to step 5 time10
Recards Vincent
11 years 10 months ago #8962 by sl1200mk2
Replied by sl1200mk2 on topic Shortcuts ??
HI Vincent,
I'll publish the 4.0.0-b15 early next week.
would you mind posting this issue in the upcoming thread.
thanx
yes at the bottom of the shortcuts window, there's an ENTER option
not easily....
a workaround would be to load the goto step in X2 (green step) and press GO
Time to create page: 0.126 seconds
