How to chaser 40 channel easly.
- amedeo
12 years 3 weeks ago #8538
by amedeo
How to chaser 40 channel easly. was created by amedeo
i would like to know if there is any possibility to chasing 40 channel in easly way ( Step by Step)
I´m using D-Light Version 3.0.18, and i never used it before for kind of special effects.
Please let me know.
greetings from Germany
Amedeo
Please let me know.
Amedeo
12 years 3 weeks ago #8539
Replied by sl1200mk2 on topic How to chaser 40 channel easly.
if you have in mind a kind of 'wizard' function like avab lightboard, there's no such thing in DL.
you have to build each step one by one...
after, shortcuts are available in the FX editor, so once you're glad with each desired channel's levels, simply use 'R' as Record.
that will record an Fx_Cue and load it in the FX sequence.
hope it helps,
hope it helps,
12 years 3 weeks ago #8540
by aroom
Replied by aroom on topic How to chaser 40 channel easly.
Yep.
Go to Display > FX
Then clic on "Create a New FX"
Select it and clic on "Edit FX" : You are now in the FX Editor
Then simply record the Cue you'll need. In @ mode, you can type "C 12 = F", then "R" to record the Cue
The first Cue will be the first step (step 0) and so on. You can edit Cue and Step order by any moment. You can choose the Time In and Time Out.
Then you may have to learn how to load a Fx in a Submaster and how to link it in a Step in your sequence using Mlink.
Check the forum.
ps. it may be a good idea to update your dlight version
Go to Display > FX
Check the forum.
12 years 3 weeks ago #8541
also 3.0.23 is better than 3.0.18...
Time to create page: 0.127 seconds
