Font Problem with DL *SOLVED*
- SaFaRi187
12 years 4 months ago - 12 years 4 months ago #8258
by SaFaRi187
Font Problem with DL *SOLVED* was created by SaFaRi187
Hi
I recently came across a "bug" in v3.0.23 (also in beta v4.0.0).
In the setup options I tried to change the font in 'police font and size'. It worked, but when I want to revert backto the original font. It gives an error message (see pic below) and for now I'm unable to change te font. No font seems to work/load...
Also strange is that all the text in the main screen is suddenly in italic...
I'm on a Late 2008 MacBook Pro running Mavericks and XQuartz 2.7.6.
Any suggestion?
Thanks in advance and keep up the good work!
Logfile:
expected integer but got "New"
while executing
"font actual $defaultFont"
(procedure "::ChooseFont::Init" line 9)
invoked from within
"::ChooseFont::Init $defaultFont"
(procedure "::ChooseFont::ChooseFont" line 57)
invoked from within
"::ChooseFont::ChooseFont "$font4seq $font4seqSize""
invoked from within
".setupMod.main.sf.scrolled.ffont.b invoke "
invoked from within
".setupMod.main.sf.scrolled.ffont.b instate !disabled { .setupMod.main.sf.scrolled.ffont.b invoke } "
invoked from within
".setupMod.main.sf.scrolled.ffont.b instate pressed { .setupMod.main.sf.scrolled.ffont.b state !pressed; .setupMod.main.sf.scrolled.ffont.b instate !di..."
(command bound to event)
Any suggestion?
Logfile:
while executing
invoked from within
invoked from within
invoked from within
invoked from within
invoked from within
Last edit: 12 years 4 months ago by SaFaRi187.
- SaFaRi187
12 years 4 months ago #8259
by SaFaRi187
Replied by SaFaRi187 on topic Font Problem with DL
Solved! I got back to XQuartz 2.7.5 and now everything is as before!
12 years 4 months ago #8260
Replied by sl1200mk2 on topic Font Problem with DL *SOLVED*
thanx for reporting issues/solutions
this is a strange bug...
I'll try to install XQuartz 2.7.6 to see what happens.
Time to create page: 0.131 seconds
