is this possible?
12 years 7 months ago #7850 by birt
is this possible? was created by birt
is it possible to run more than one sequence list in Dlight? so i can have some lights fading over a long time in a second sequence while running cues in my main sequence? what would be really nice is to have the option to select what effect both sequences have on each other. LTP, HTP, one sequence setting the maximum level that the other one can not exceed...
also i'd like to know if Dlight can send MIDI cues. i could for example have a slow pulsing movement on the grand master by having it controlled by a MIDI sequence. but it's nice if this midi sequence (coming from a different program) can be trigggered by a previous cue in Dlight.
i know i'm asking a lot of crazy stuff here...
12 years 7 months ago #7856 by sl1200mk2
Replied by sl1200mk2 on topic is this possible?
Hi,
no, not yet....
I've this project to multiply the numbers of sequence, but it's not on the top on the todo list...
MLink are generally used to trigger stuffs idependently on the sequence.
you can have something running over xxx minutes while you continue the main cue list.
I'm working with a console in LTP right now and I'm not very satisfied of this way of working... at least as it is...
hope I'll do better when LTP will be injected in DL
no, but in OSC you can have the cue number exported over the network...
hope you do ;-)
