Dimmer / channel inhibition (request)
13 years 1 week ago #6846 by Wilf
When I am touring I use inhibition a lot of course, because every venue has its own set of lamps and light distances.
One thing that I sometimes do wrong is the following: Inhibition sets the maximum percentage of the channel. That is logical. What is less logical is that one has to set the inhibition to 0 in stead of FF to reset the inhibition. So when I set inhibition to 99 it's almost full but at 100% it's completely off. I think it's a bit counter-intuitive.
Another thing that I sometimes miss is to set a dimmer inhibition. I will explain why:
Sometimes I use multiple lights for one channel. A good example is the audience lighting. I mostly use channel 100 for this. In some venues they use 50 dimmers for the audience light and let's say that 10 of those dimmers have to be max 70% and 10 max 80%, 5 max 90% and 5 max 20%. In a 'normal' desk lighting console one will then change the max level of the dimmers in stead of making more channels and program these in all of your cues (when one uses them there).
Maybe something for future releases?
Oh, one more thing: Can I change the default map setting? When (for example) opening a custom curve I always have to search the hard drive for the right folder.
Cheers, Wilf
13 years 1 week ago - 13 years 1 week ago #6848 by sl1200mk2
Replied by sl1200mk2 on topic Dimmer / channel inhibition (request)
you're right, but I did it that way because it looks like the TimeGroup way of operating.
in the TGroup editor, asking for 0 [TIME] for a channel leads to remove the channel from the editor.
this is why...
totally agree with you.
I do that with the curves.
but you're right there's a huge difference between setting a max value for a dimmer and setting a max top level for a dimmer.
the first curve look like this
Code:
_____ / / /
while the second is still linear with a under 255 top level.
one can choose the way he prefers working, so it can be a part of a future release (you'll need to ask for it again at the next beta stage; I want to publish 3.0.17 asap)
DL is first looking into the folder where all requested files are... that means the (invisible) DLightWorkingSho directory.
that is design to be able to copy curve from a dimmer to another without the need to look after the *recently* created curves.
Last edit: 13 years 1 week ago by sl1200mk2.
The following user(s) said Thank You: Wilf
13 years 1 week ago - 13 years 1 week ago #6849 by Wilf
Replied by Wilf on topic Dimmer / channel inhibition (request)
Thanks for your swift and great responses. The dimmer inhibition would be a great add on for 3.0.18.
I'm currently running my show in a theater with 12 DMX channels for light consisting of different filaments and made a few custom curves.
By the way: Do you know an easy way to draw a graph and output it to CSV? When Googling every answer is the other way round. I could make it in Pure Data if there is no other way but I'll have to brush up my textfile-writing skills in Pd first...
Last edit: 13 years 1 week ago by Wilf.
13 years 5 days ago #6870 by sl1200mk2
I guess the easiest way is with Excel or LibreOffice.
but I cannot tell you the best way to do so....
Time to create page: 0.129 seconds
