leter??
13 years 2 months ago #6624 by paucurses
leter?? was created by paucurses
The problem is not solved since the keyboard. When I press any key (backspace either as a command from the shortcut) I get the key in question pursued two interogants = t?? ... How to solve it? I hope quick response!
Thank you!
13 years 2 months ago #6625 by sl1200mk2
Replied by sl1200mk2 on topic leter??
hi,
it's difficult to understand what you mean...
for example, when you presse the key e, what do you get?
do you get e??
in that case, can you please specify wich keyboard do u have and wich language configuration.
13 years 2 months ago #6626 by paucurses
Replied by paucurses on topic leter??
But where I have to change the settings ...?
13 years 2 months ago #6627 by sl1200mk2
it was a question...
when you type e, do you get e??
13 years 2 months ago #6628 by paucurses
Exactly as would have to be to work properly? I had always worked ... In the latest version has stopped working. I in previous versions I also now works properly.
13 years 2 months ago #6629 by paucurses
YES.
13 years 2 months ago #6630 by sl1200mk2
did you try with the latest beta?
13 years 2 months ago #6631 by paucurses
I would say no .. I spent .15 of the .16 ... But now old Verison not succeed ...
13 years 2 months ago #6632 by paucurses
What is the solution?
13 years 2 months ago #6633 by paucurses
Above version 3.0.11 does not work. Below all right. I use Windows 7!!! HELP PLIS
13 years 2 months ago #6636 by sl1200mk2
Hi,
i cannot reverse to such a far release...
so sorry but I do *not* have a solution for you.
here it works as expected.
13 years 2 months ago #6637 by paucurses
What is the difference between hard keyboard version 3.0.11 and 3.0.16? Here is the solution. Explain please
13 years 2 months ago #6638 by sl1200mk2
I don't know what is different for you (as I told you, it works on every computer I tried).
13 years 2 weeks ago #6773 by paucurses
The problem is now solved!
Time to create page: 0.161 seconds
