Fx in step?
13 years 7 months ago #5827 by p.leijstra
Fx in step? was created by p.leijstra
Hi, can anyone help me how to activate an effect on a step?
I already have an effect applied to the submaster. I presses Rlink in the step and I see it at Rlink (target FF) but it does not seem to play when the step is active.
How do I start the effect?
Thnx in advance!
13 years 7 months ago #5829 by sl1200mk2
Replied by sl1200mk2 on topic Fx in step?
MLink is the way to launch FX within a step.
recording MLink with the RLink (RecordLink) is a good thing.
MLink are processed with the GO command.
thus if you have in X2 a step loaded with MLink associated, the next time you press GO, MLink will be triggered.
ps: you'll be able very soon to write all these missing part in the Wiki ;)
13 years 7 months ago #5831 by p.leijstra
Replied by p.leijstra on topic Fx in step?
Ok, but then it wil only play as long as the fade-in time lasts? How can I play the FX untill I go to the next step?
13 years 7 months ago #5834 by sl1200mk2
Mlink are independent of the times registered within the steps, you can for example set a time for a mlink of 20 minutes and have time for a step set to 1 second.
the step will xfade in 1 second and the Linked submaster will fade In(or Out) in 20 minutes.
after that the submaster is opened and you need to set another MLink if you want to close it.
on the next step, you set another MLink to close the submaster that contain the FX.
13 years 7 months ago #5837 by p.leijstra
Ok, so on the next step you repeat the mlink, but set the level to 0 in stead of FF?
I'm do not see my Fx playing (I do'nt see the values of the channels changing when I press go) The fx only plays when I set the sub to FF manualy, or is this normal that I don't see it?
Thanks allot!
13 years 7 months ago #5839 by sl1200mk2
right.
nope.
can you post your sho to have a look?
13 years 7 months ago #5842 by p.leijstra
Ok, I added the show.
On step 3 the mlink is added.
Thanks!
13 years 7 months ago #5845 by sl1200mk2
I do not see any MLink in the sho you've posted...
in the MLink editor, don't forget to click on 'Valid' to save MLinks (or use the 'Modify' shortcut)
13 years 7 months ago #5848 by p.leijstra
I'm sorry. I was working on the show, but did not save it yet.
here it is again, now with mlink
13 years 7 months ago #5849 by sl1200mk2
indeed, your sub isn't fired...
looks like you've found a bug.
I'm working on Colin's one, and after I'll fix yours.
and after it will be time for a next beta...
13 years 7 months ago #5850 by p.leijstra
Great, finaly I contributed (in a way ;))
Is it also possible (maybe in a beta-beta-version) to use the Enttec Pro with the original driver? This because I use the enttec in other software as well. (or would this be very difficult?) In that case the installing of the liusbx driver is also not necessary..
13 years 7 months ago #5852 by sl1200mk2
Piet,
in the setup, when 'Inhib MLink' is active, that means that MLink won't be processed.
idem for 'Inhib Wait Times'
these options are usefull when you want to check particular feature of the sequence without being polluted by subs or whatever.
so unselect the options and you'll see that the sub is fired
on MacOS you can by selecting /dev/usb-serial as 'modus operandi'
BUT, FTDI drivers have a limited size buffer of 1K and in the case of several univers, it leads to error.
so always use libusbx as 'modus operandi' as this lib is chunking memory.
13 years 6 months ago #5881 by p.leijstra
Ah right! Indeed, when I uncheck the inhib it does work!
I's using the FTDI driver also possible on windows? For now I only use 30 dmx channels, so no real problem with that I suppose ;)
Again great help!
Greets
13 years 6 months ago #5891 by sl1200mk2
nope, libusbx is the way I've choose...
Time to create page: 0.183 seconds
