- Thank you received: 22
Fade times
- colinc
If I try as above eg 'Step' is in 'Prepas' (green box around) , then type eg [CH]1 [THRU] 5 [@][50][TIME] 1 [TimeGroup] <Return>sl1200mk2 wrote: 2 ways.
-with shortcut:
if X2 is the active register (the green one), you select channel(s) that you want to be controled by a TGroup (for ex ch 1 thru 10),
you type the desired time (1 for 1 second) and you hit the timegroup shortcut ('z' by default)
I get the 'Bad Sentence' error box
Regards
I think you should remove the [TIME] and directly call [TGROUP].
- colinc
sl1200mk2 wrote: @Colin
Only works like that in RPN Mode
would you mind writing this in 3.0.12_b9 thread?Only works like that in RPN Mode
I'll fix this for the next one.
