- Thank you received: 1
intérêt pour l'application
- p.leijstra
Thanks in advance,
Piet
- colinc
- Thank you received: 22
- noelvd
- Thank you received: 4
:Light (but I have 15 years of experience in lighting). Being an Apple-fan, and in possession of an iPad and an iPod, I have purchased TouchOSC (4.49 Euro at the AppStore, and worth every cent). The (free!) editor (TouchOSC Editor, can be downloaded on this page :
hexler.net/software/touchosc
).Right now, I have 1 template for the iPad, and 1 for the iPod. The iPad set has a page with the GrandMaster, the SubMasters, and the first 60 channels (= first page of channels in
:Light). The second page (under construction) is to control a projector that has 256 LEDS (in red, green, blue and white, 64 of each), and ONE CHANNEL PER LED. That's 256 channels (on/off) for this one projector. The page has 256 Push-buttons, in the same colors and layout as the projector. I now need to set up the correct channel for each button, but once that is done, I can easily 'program' the projector.For the iPod, I have another template, with 1 page with the 10 SubMasters, and 1 with the first 60 channels.
1 caveat in this setup:
:Light accepts (=receives) commands from multiple devices (= iPod and iPad at the same time), but only SENDS ('writes') to ONE device at the time (iPad, in my case).By the way, I also have a BCF2000, with the 8 faders configured to operate the first 8 SubMasters. That works great, and the faders on the iPod/iPad move along as you move the fades on the BCF2000 (and vice versa).
If your intrested in the templates, let me know, and I will upload them (there on my other MacBook).
[Ik spreek/lees/schrijf ook nederlands, want ik ben belg/vlaming
did you tried to set the writer address wit 255 at the end?1 caveat in this setup:
x.x.x.255 means broadcast in wich case, all device registered on the network x.x.x should receive the information.
also,
we have created a page to register DL tools here
github.com/dlight-tools
If you register an account on github, I think you should be able to ask for a pull-request to upload your work in the dlight-pad/touchosc section.
Nico
- noelvd
First of all : You did/do an EXCELLENT JOB with DL !
I will give the .255 a try, and let you know how that worked.
It's not a real problem. It will not happen to often that I use iPod and iPad at the same time.
I will also upload the templates as soon as I can (they're on my other MacBook).
Best regards / Bien à toi,
Noël
thanx very much.First of all : You did/do an EXCELLENT JOB with DL !
no but for the show I'm touring (for example), we are 2 to focus at the same time and it would be great if broadcasting works (I didn't try it for the last one we did...)I will give the .255 a try, and let you know how that worked.
/seq/master xx
in order to remotely control the new scene Master.
- p.leijstra
Is there anybody ho knows how
:light communicates with the enttec usb pro device? (what kind of communication, what ports and what packets?)I'm looking for a solution to use both d::light, but also be able to controll dmx from flash.
Thanks in advance.
DL uses libusbx to open/communicate with usbPro.Is there anybody ho knows how
libusbx.org/
I choose this one because it's Xplatform and people's coding style/choices are good.
as long as you can find a tool to transcode Flash/OSC, you can use DL to transcode OSC/DMXI'm looking for a solution to use both d::light, but also be able to controll dmx from flash.
benchun.net/projects/flosc/
bubblebird.at/tuioflash/guides/sending-osc/
www.kasperkamperman.com/blog/flash-osc-a...y-osc-communication/
(all are results of google 'Flash Osc')
- noelvd
I signed up for github, but I don't find how to upload a file. Can you help ?
I'll let Colin answer you on this as we did it to merge his dlight-pad fork.
I think you need to ask for a pull request but I'm not sure.
- noelvd
- p.leijstra
sl1200mk2 wrote: DL uses libusbx to open/communicate with usbPro.
libusbx.org/
Can you tell me what packets get send to the entecc device, or point me in a direction where i can find it?
I allready had such a communication from flash via OSC to dmx, but you neet like 3 programms, from flash utp to a brigde (flosc or netlab) which transfers from utp or xml to OSC then
:light or other software to go from OSC to serial communication. I want to reduce the ammount of programm's I need, by going from flash via a bridge (serproxy for example) straight to serial, But then i need to know what serial communication takes places and how that works using libusbx.Thanks in advance!
you can have a look to libftdi. it's plain C but their code is well commented
www.intra2net.com/en/developer/libftdi/repository.php
