D::Light et Debian 6.0.6 64bits
- rothastha
13 years 7 months ago #5513
by rothastha
D::Light et Debian 6.0.6 64bits was created by rothastha
Bonsoir,
Après avoir suivi l'intégralité des manipulations d'installation du Wiki,
il s'avère que le programme ne se lance pas : il affiche plusieurs codes d'erreur indiquant des librairies manquantes :
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.15' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.15' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libolacommon.so.0)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libolacommon.so.0)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libola.so.1)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libtcl8.5.so)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.15' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libtcl8.5.so)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libtk8.5.so)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libnettle.so.4)
xxxxxxxxxxxxx/Logiciels/DLight/bin/DLight: /lib/libc.so.6: version `GLIBC_2.14' not found (required by xxxxxxxxxxxxx/Logiciels/DLight/bin/libprotobuf.so.7)
Malheureusement les librairies manquantes ne le sont pas ( elles sont bel et bien présentes sous /lib
, en contrepartie, avec des versions de GLIBC différentes des versions embarquées puisque
:Link réclame une version 2.14 ou 2.15 pour tcl, or sous debian 6.0.6 nous n'en sommes qu'à la
version 2.11.3-4 pour squeeze et 2.13-38 pour sid
Auriez vous une solution ?
D'avance merci de vos réponses
ps : J'ai appris, par ailleurs que la version debian instable de cette librarie 2.13.xx provoque encore actuellement des crash système :S
et est donc totalement à proscrire de même que l'option de changer d'OS pour faire tourner
:Light.
:Link réclame une version 2.14 ou 2.15 pour tcl, or sous debian 6.0.6 nous n'en sommes qu'à laversion 2.11.3-4 pour squeeze et 2.13-38 pour sid
:Light..
13 years 7 months ago #5514
Replied by sl1200mk2 on topic D::Light et Debian 6.0.6 64bits
comment lances tu DL? est-ce que tu exécutes bien le script DLight.sh?
sinon, a priori, les librairies fournies par DL requièrent la libc. normal, DL est codé en C.
mais la libc qui est présente sur ton système demande la GLIBC 2.tropRécentPourTonSystème.
ne pourrais-tu pas downgrader la libC de ton système pour qu'elle accepte ta GLIBC?
The following user(s) said Thank You: rothastha
- mika
- Thank you received: 3
13 years 7 months ago #5516
by mika
Replied by mika on topic D::Light et Debian 6.0.6 64bits
si je peux me permettre, la libc (aka la fichier /lib/libc.so.6) fait partit integrante de la glibc puisque le but premier de celle-ci est de fournir la bibliothèque C standard au système.
Donc, je ne vois que deux solutions :
- utiliser une distribution qui a une glibc à jour pour dlight
- recompiler dlight avec une glibc plus ancienne (et voir si ça ne posera pas de problèmes sur les systèmes plus à jour)
- rothastha
13 years 7 months ago #5519
by rothastha
Replied by rothastha on topic D::Light et Debian 6.0.6 64bits
Merci de ta réponse je suis en accord avec toi pour la recompilation ....
Mais où trouve t'on les sources de Dlight ??
- rothastha
13 years 7 months ago #5520
by rothastha
Merci pour ta réponse, mais c'est bizarre, il me semblait le contraire : c'est la glibc de Dlight qui est comme le dit mika ci dessous, plus récente que celle présente sous debian 6.06 squeeze
et comme la lib en 2.13 ( et pas 2.14 comme demandé par Dlight ) est instable encore actuellement sous debian squeeze
13 years 7 months ago #5545
vous avez raison et cette page du wiki explique bien tout:
fr.wikipedia.org/wiki/GNU_C_Library
maintenant, les sources de DL n'étant pas publique, tu ne peux pas recompiler DL pour ton système et je n'ai pas de système inférieur (en terme de libc) sur lequel je pourrais recompiler DL.
ça a toujours été un problème avec le main de Debian....
tu peux peut-être essayer de compiler la derniere GLibc, la mettre dans le répertoire Lib de DL et tenter de lancer le script sh (étant donné que le script lance un ldconfig avant de lancer DL, ça pourrait fonctionner).
Time to create page: 0.158 seconds
