allocate memory
14 years 3 months ago #4923 by paucurses
allocate memory was created by paucurses
Hello
I have a dupte - It is possible to load a memory? This should come when you go to GO ... A similar function would be: allocate the cross-fader, the go (in LT)
I hope to answer. thank you
14 years 3 months ago #4926 by sl1200mk2
Replied by sl1200mk2 on topic Re: allocate memory
hi,
it's not very clear for me what you ask...
but there's a shortcut called 'cue_goto' you should have a look
select preparation Registre (the green one) use 'cue_goto' to load your cue and press GO.
hope this helps.
14 years 3 months ago #4927 by paucurses
Replied by paucurses on topic Re: allocate memory
Thank you! Is that! A perfect application!
Time to create page: 0.127 seconds
